Lifters for a Indy maxx block w/572-13 heads #234288
02/23/09 08:21 PM
02/23/09 08:21 PM
Arkansas
JoWeTu_6 Offline OP
JoWeTu_6  Offline OP
Arkansas
Ok can anyone recomend a set of lifters, I wanted to use crans 66542-16 but I was told I could use their 13570-16, is their a jesel or another
realy good brand I should be looking at?
I need somones
thanx
Re: Lifters for a Indy maxx block w/572-13 heads [Re: JoWeTu_6] #234289
02/23/09 10:20 PM
02/23/09 10:20 PM
You need to run a offset lifter with the 572-13 heads...I would run Isky or Crane..Lunati is now making them as well, which is my personal favorite. Of course Indy has them, they are made by Comp.
Re: Lifters for a Indy maxx block w/572-13 heads #234290
02/24/09 12:11 AM
02/24/09 12:11 AM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
The Jesels Are SWEET but they are also over 2 large.
Re: Lifters for a Indy maxx block w/572-13 heads [Re: sasquatch] #234291
02/24/09 01:39 AM
02/24/09 01:39 AM
SoCal
Brian Hafliger Offline
SoCal
I recommend these:
Re: Lifters for a Indy maxx block w/572-13 heads [Re: JoWeTu_6] #234292
02/24/09 08:57 AM
02/24/09 08:57 AM
Kentucky
sc301v Offline
sc301v  Offline
Kentucky
OU812 you have a P.M.
Re: Lifters for a Indy maxx block w/572-13 heads [Re: Brian Hafliger] #234293
02/24/09 06:33 PM
02/24/09 06:33 PM
Arkansas
JoWeTu_6 Offline OP
JoWeTu_6  Offline OP
Arkansas
What r those "crower, crane, jesel" ?
Re: Lifters for a Indy maxx block w/572-13 heads [Re: JoWeTu_6] #234294
02/25/09 11:03 AM
02/25/09 11:03 AM
Arkansas
JoWeTu_6 Offline OP
JoWeTu_6  Offline OP
Arkansas
Thanks for all the help you guys.
Till my next issue in this build
JoWeTu_6
Re: Lifters for a Indy maxx block w/572-13 heads [Re: JoWeTu_6] #234295
02/25/09 11:20 AM
02/25/09 11:20 AM
North Cackilacky
sdaurity Offline
sdaurity  Offline
North Cackilacky
Am I crazy or are those pistons in upside down?
One day I will have something cool here.
Re: Lifters for a Indy maxx block w/572-13 heads [Re: sdaurity] #234296
02/25/09 11:27 AM
02/25/09 11:27 AM
Jacksonville, NC
RonP Offline
RonP  Offline
Jacksonville, NC
X2 or I am Crazy X2
Re: Lifters for a Indy maxx block w/572-13 heads [Re: RonP] #234297
02/25/09 11:53 AM
02/25/09 11:53 AM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
X2 or I am Crazy X2
You guys need to look again..The valve layout is correct... EIIEEIIE
Re: Lifters for a Indy maxx block w/572-13 heads [Re: JoWeTu_6] #234298
02/25/09 12:10 PM
02/25/09 12:10 PM
Colorado,U.S.A
4404dart Offline
4404dart  Offline
Colorado,U.S.A
I am doing the same thing. I think you should take into account what spring preasures you will need. Some of the lifters out there may not hold up to high spring preasures.
Re: Lifters for a Indy maxx block w/572-13 heads [Re: Bob_Coomer] #234299
02/25/09 12:35 PM
02/25/09 12:35 PM
Jacksonville, NC
RonP Offline
RonP  Offline
Jacksonville, NC
X2 or I am Crazy X2
oh I agree that valve layout is correct. But they appear to be upside down. Maybe those pistons are different than the last few sets I have used. or I really am crazy.
Re: Lifters for a Indy maxx block w/572-13 heads [Re: Bob_Coomer] #234300
02/25/09 12:36 PM
02/25/09 12:36 PM
North Cackilacky
sdaurity Offline
sdaurity  Offline
North Cackilacky
Re: Lifters for a Indy maxx block w/572-13 heads [Re: sdaurity] #234301
02/25/09 12:55 PM
02/25/09 12:55 PM
Jacksonville, NC
RonP Offline
RonP  Offline
Jacksonville, NC
I was expecting it to look more like this
Re: Lifters for a Indy maxx block w/572-13 heads [Re: 4404dart] #234302
02/25/09 01:02 PM
02/25/09 01:02 PM
Arkansas
JoWeTu_6 Offline OP
JoWeTu_6  Offline OP
Arkansas
Your right 4404dart , but heads-up and RonP have seen something their wright ,also somthing I noticed when I recived the pistons from INDY cylinder head but just couldnt put my finger on it . It took me a couple of weeks but look at the valve angle on your stock heads then look at this pic again. Thats right there not stock there 15 degree pistons, they should be 13 degree pistons for 572-13 heads they sent me the wrong pistons, I sent them back over a mounth ago and I've been trying to get the right pistons from them sence then, it's like they have disapeared into the black hole of nobody knows . To this day no luck as yet .
This is what whimsicals I've been redused to
JoWeTu_6
Re: Lifters for a Indy maxx block w/572-13 heads [Re: JoWeTu_6] #234303
02/25/09 01:06 PM
02/25/09 01:06 PM
Arkansas
JoWeTu_6 Offline OP
JoWeTu_6  Offline OP
Arkansas
Oh by the way, VERY VERY NICE 4404dart
Re: Lifters for a Indy maxx block w/572-13 heads [Re: JoWeTu_6] #234304
02/25/09 01:23 PM
02/25/09 01:23 PM
Jacksonville, NC
RonP Offline
RonP  Offline
Jacksonville, NC
Well I hope you get it sorted out. Looks like a killer ride.
Re: Lifters for a Indy maxx block w/572-13 heads [Re: RonP] #234305
02/25/09 01:29 PM
02/25/09 01:29 PM
North Cackilacky
sdaurity Offline
sdaurity  Offline
North Cackilacky
X2 Good luck
Re: Lifters for a Indy maxx block w/572-13 heads [Re: RonP] #234306
02/25/09 01:30 PM
02/25/09 01:30 PM
Arkansas
JoWeTu_6 Offline OP
JoWeTu_6  Offline OP
Arkansas
So do I, I cant belive the probs I'm having with them
JoWeTu_6
Re: Lifters for a Indy maxx block w/572-13 heads [Re: JoWeTu_6] #234307
02/25/09 08:36 PM
02/25/09 08:36 PM
San Jose Ca.
boatracer572 Offline
San Jose Ca.
pistons are upsidown
