Lifters for a Indy maxx block w/572-13 heads
#234288
02/23/09 08:21 PM
02/23/09 08:21 PM
Posts: 345 Arkansas
JoWeTu_6
Arkansas
Ok can anyone recomend a set of lifters, I wanted to use crans 66542-16 but I was told I could use their 13570-16, is their a jesel or another realy good brand I should be looking at? I need somones thanx
Re: Lifters for a Indy maxx block w/572-13 heads
[Re: JoWeTu_6]
#234289
02/23/09 10:20 PM
02/23/09 10:20 PM
You need to run a offset lifter with the 572-13 heads...I would run Isky or Crane..Lunati is now making them as well, which is my personal favorite. Of course Indy has them, they are made by Comp.
[Re: JoWeTu_6]
#234292
02/24/09 08:57 AM
02/24/09 08:57 AM
Posts: 364 Kentucky
sc301v
Kentucky
[Re: Bob_Coomer]
#234299
02/25/09 12:35 PM
02/25/09 12:35 PM
Posts: 1,633 Jacksonville, NC
RonP
Jacksonville, NC
X2 or I am Crazy X2
You guys need to look again..The valve layout is correct... EIIEEIIE
oh I agree that valve layout is correct. But they appear to be upside down. Maybe those pistons are different than the last few sets I have used. or I really am crazy.
[Re: 4404dart]
#234302
02/25/09 01:02 PM
02/25/09 01:02 PM
Posts: 345 Arkansas
JoWeTu_6
Arkansas
Your right 4404dart , but heads-up and RonP have seen something their wright ,also somthing I noticed when I recived the pistons from INDY cylinder head but just couldnt put my finger on it . It took me a couple of weeks but look at the valve angle on your stock heads then look at this pic again. Thats right there not stock there 15 degree pistons, they should be 13 degree pistons for 572-13 heads they sent me the wrong pistons, I sent them back over a mounth ago and I've been trying to get the right pistons from them sence then, it's like they have disapeared into the black hole of nobody knows . To this day no luck as yet . This is what whimsicals I've been redused to JoWeTu_6
