95 Dakota not charging 4 different alt, same response... #2343010
07/25/17 12:35 PM
07/25/17 12:35 PM
Freeport IL USA
poorboy Online content OP
poorboy  Online Content OP
Freeport IL USA
Ok, my grandson's 95 Dakota started discharging and killing the battery, so he did the standard repair, a junk yard alt. still not charging. 2nd junk yard alt, still not charging.
I had an alt pulled off a known good truck thats been sitting on the shelf a few years, swapped that in, still not charging.
whats next?
I assume the charging system is regulated by the computer, can we add an old electronic voltage regulator and get this thing going for a while? Gene
Re: 95 Dakota not charging 4 different alt, same response... [Re: poorboy] #2343023
07/25/17 01:04 PM
07/25/17 01:04 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
It's pretty common for the charging part of the PCM to go, the option is an expensive PCM or external regulator. These are a pretty good set of instructions http://www.backyardmechanic.org/how-to-build-a-external-voltage-regulator-for-dodge-jeep-chrysler/
Re: 95 Dakota not charging 4 different alt, same response... [Re: poorboy] #2343220
07/25/17 07:11 PM
07/25/17 07:11 PM
Freeport IL USA
Freeport IL USA
Great info! we have ordered parts and will probably be doing the external voltage regulator tomorrow. Gene
