Where did you get your front disc conversion? #234138
02/23/09 08:23 PM
02/23/09 08:23 PM
roanoke va
kbcuda Offline OP
kbcuda  Offline OP
roanoke va
Thinking about converting my '70 satellite. Would finding a donor car be easier/cheaper?
Re: Where did you get your front disc conversion? [Re: kbcuda] #234139
02/23/09 08:56 PM
02/23/09 08:56 PM
Alone in the darkness
gamagoat6x6 Offline
super street
gamagoat6x6  Offline
super street
I got mine at Union auto parts. $20 for everything with thick useable rotors.
`02 RAM2500 SPORT V10 4x4 `06 GMC sierra NO cars
Re: Where did you get your front disc conversion? [Re: kbcuda] #234140
02/23/09 10:42 PM
02/23/09 10:42 PM
AndyF Online content
AndyF  Online Content
Late model A body car or FMJ car is probably the easiest way to go. Might still find something in a wrecking yard or you can usually find the knuckles for sale in the parts area.
Re: Where did you get your front disc conversion? [Re: kbcuda] #234141
02/24/09 03:29 PM
02/24/09 03:29 PM
cal
str12wedge Offline
str12wedge  Offline
cal
I got my spindle off a 86` new yorker from my local junk yard $10 then bought the calipers and rotors for a 70` satellite from napa auto store and master cylinder also change the proportion valve.
Re: Where did you get your front disc conversion? [Re: str12wedge] #234142
02/24/09 03:37 PM
02/24/09 03:37 PM
I got mine from a 73' Demon.
Re: Where did you get your front disc conversion? #234143
02/24/09 05:23 PM
02/24/09 05:23 PM
roanoke va
kbcuda Offline OP
kbcuda  Offline OP
roanoke va
the spindles are that interchangeable? Isn't the upper control arm different betwen drum/disc brake spindles?
Re: Where did you get your front disc conversion? [Re: kbcuda] #234144
02/24/09 06:01 PM
02/24/09 06:01 PM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
I got my stuff from www.scarebird.com easy and used OEM GM parts. So if that bothers you it may not be what you want.
Re: Where did you get your front disc conversion? [Re: kbcuda] #234145
02/24/09 06:02 PM
02/24/09 06:02 PM
Yes, the knuckles are very interchangeable. Any B body knuckle will fit your B body, any E body will fit, any FMJ knuckle will fit, any R body knuckle will fit, and any A body from 1973 or newer will fit. All bolt in without any changes. Any of those knuckles can fit on either side so you can hang the calipers to the front or to the rear.
Re: Where did you get your front disc conversion? [Re: AndyF] #234146
02/24/09 06:06 PM
02/24/09 06:06 PM
roanoke va
kbcuda Offline OP
kbcuda  Offline OP
roanoke va
so i can use my current drum brake upper control arm and ball joint?
Re: Where did you get your front disc conversion? [Re: Dakota_Don] #234147
02/24/09 06:16 PM
02/24/09 06:16 PM
roanoke va
kbcuda Offline OP
kbcuda  Offline OP
roanoke va
were you satisfied with the quality and performance? Those brackets look a little flimsy to me..
Re: Where did you get your front disc conversion? #234148
02/24/09 06:57 PM
02/24/09 06:57 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
73 Dart Sport??
Re: Where did you get your front disc conversion? [Re: rrunner] #234149
02/24/09 06:59 PM
02/24/09 06:59 PM
73 Dart Sport??
Yes. A Dart Sport
Re: Where did you get your front disc conversion? [Re: kbcuda] #234150
02/24/09 07:37 PM
02/24/09 07:37 PM
cal
str12wedge Offline
str12wedge  Offline
cal
yes you can. plus is less expensive and all mopar parts...
Re: Where did you get your front disc conversion? [Re: str12wedge] #234151
02/24/09 08:58 PM
02/24/09 08:58 PM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
85 Diplomat... bough the whole thing, calipers, knuckles,rotors, and pads.
Re: Where did you get your front disc conversion? [Re: kbcuda] #234152
02/24/09 11:16 PM
02/24/09 11:16 PM
northeast ohio
mkdart Offline
mkdart  Offline
northeast ohio
If you can spend a few extra bucks, do yourshelf a favor and use tubular A arms from the start.
Re: Where did you get your front disc conversion? [Re: mkdart] #234153
02/24/09 11:39 PM
02/24/09 11:39 PM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
At a salvage yard back in 96. I got the spindles and rotors from a 74 duster with the sissor/brake booster bracket....oh and the upper control arms. The caliper brackets and calipers were gone. I look over at the car next to it which was an 80 diplomat and took the caliper bracket off and caliper over and put on the 74 Duster and it worked. Then I put it all on my 64 Valiant.
Moparlee
Re: Where did you get your front disc conversion? [Re: Robbins] #234154
02/25/09 01:27 AM
02/25/09 01:27 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Wrecking yards, several times. Swap meets a few times. A few times the car even came with them.
Re: Where did you get your front disc conversion? [Re: Jim_Lusk] #234155
02/25/09 01:58 AM
02/25/09 01:58 AM
WI, USA
67dodge67 Offline
mopar addict
67dodge67  Offline
mopar addict
WI, USA
Doctor Diff!
Re: Where did you get your front disc conversion? [Re: 67dodge67] #234156
02/25/09 11:15 AM
02/25/09 11:15 AM
roanoke va
kbcuda Offline OP
kbcuda  Offline OP
roanoke va
anyone use these? special rotors so you don't need to change spindle..
http://store.summitracing.com/partdetail...mp;autoview=sku
Re: Where did you get your front disc conversion? [Re: kbcuda] #234157
02/25/09 11:33 AM
02/25/09 11:33 AM
Frederick, MD
71charger Offline
71charger  Offline
Frederick, MD
'77 Volare for the front, Dr. Diff for the rear
