Need Hemi E body help... #234094
02/23/09 07:07 PM
02/23/09 07:07 PM
florida
P
PJM Offline OP
PJM  Offline OP
P
florida
Anyone out there with a Hemi E body with original motor mounts and correct K member give me the following measurements?
1) Top of K member to center of crankshaft
2) Drivers side framerail to center of crankshaft
3) Passenger side framerail to center of crankshaft
Also does the engine sit level from front to back or is there a degree of angle?
Any help appreciated.
Re: Need Hemi E body help... [Re: PJM] #234095
02/27/09 10:40 PM
02/27/09 10:40 PM
florida usa
boston Offline
boston  Offline
florida usa
Want help?
Get rid of that old crappy Dodge.
I'll give you 50 bucks.
Re: Need Hemi E body help... [Re: PJM] #234096
02/28/09 10:18 AM
02/28/09 10:18 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
TTI supplied that information on my header instruction sheet for my 440 in a 1970 e-body. They want to be sure you engine is in the stock location to eliminate fitment problems. Look on their website for the PDF version of their instructions for the Hemi and you'll probably find it.
Re: Need Hemi E body help... [Re: boston] #234097
02/28/09 11:35 AM
02/28/09 11:35 AM
florida
P
PJM Offline OP
PJM  Offline OP
P
florida
Hey Boston! Im suprised you would go as high as $50 you cheap bas7ard!
Re: Need Hemi E body help... [Re: jbc426] #234098
02/28/09 12:05 PM
02/28/09 12:05 PM
florida
P
PJM Offline OP
PJM  Offline OP
P
florida
Thanks for the reply jbc426. I have the tti instructions but they do not say what the distance should be from right and left frame rail only that they should be 2 1/2 inches difference. I an looking for the exact measurements.
Re: Need Hemi E body help... [Re: PJM] #234099
02/28/09 12:22 PM
02/28/09 12:22 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
For what it's worth, mine looks like roughly 14 1/4" from the passenger side and about 17" from the driver's side frame rails, but when there was less stuff in the way I measured and there was almost exactly 2 1/2" difference.
Re: Need Hemi E body help... [Re: jbc426] #234100
02/28/09 12:40 PM
02/28/09 12:40 PM
florida
P
PJM Offline OP
PJM  Offline OP
P
florida
Thank you! Thats exactly what I have too
