Reusing torque to yield Rod bolts #2340923
07/21/17 12:47 PM
07/21/17 12:47 PM
Virginia Beach, VA
O
Old School Offline OP
O
Virginia Beach, VA
I have a set of Oliver connecting rods. Does anyone know if you can reuse these torque to yield Rod bolts that come with them?
68 cuda formula S 588" bb 5sp
70 CUDA CONVERT 500" 5SP (SUBLIME)
70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: Reusing torque to yield Rod bolts [Re: Old School] #2340945
07/21/17 01:38 PM
07/21/17 01:38 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
What is inscribed on the head? WSB? They are not torque to yield. Their torque procedure is to insure the bolt is stretched the correct amount. If your in doubt i.e. used rods,450 passes, replace them. That's the only way I've seen an Oliver rod fail is at the bolt.
Re: Reusing torque to yield Rod bolts [Re: Old School] #2340950
07/21/17 01:45 PM
07/21/17 01:45 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Call Oliver
Re: Reusing torque to yield Rod bolts [Re: FastmOp] #2340971
07/21/17 02:25 PM
07/21/17 02:25 PM
Virginia Beach, VA
O
O
Virginia Beach, VA
just found their number. talked to tech and he said re-use only 3 times. also confirm the stretch....
