Re: RB Intake Manifold and EFI (TBI)
[Re: ChrgrCuda]
#2346523
08/01/17 01:27 AM
08/01/17 01:27 AM
Posts: 31,071 Oregon
AndyF
Here is a picture of the ProFlo that I had for a while. (sold it on Moparts to a member)
I don't have a ruler in the picture but you can kind of figure out how tall it is by looking at the other parts on the engine. I think the Pro Flo is roughly the same height as a Victor intake plus a carb. So you are saving a couple of inches that the air cleaner usually takes up.
The hassle is the throttle body clearance around the thermostat housing and upper radiator hose and all of that stuff. I'm sure people have figured it out but I haven't seen a lot of pictures posted. There is at least one Moparts member who has a Pro Flo in his E body. I remember seeing pictures of it before and it looked really clean.
The good news is if you go CNP you can ditch the distributor and use one of my cam sync units. That eliminates a bunch of interference issues with the throttle body and the distributor and cleans up the front of the engine.
[Re: ChrgrCuda]
#2346540
08/01/17 02:33 AM
08/01/17 02:33 AM
Posts: 941 Texas, USA
ChrgrCuda
Texas, USA
Dam. That's super slick. If I'd known that would possibly fit under my stock hood I'd gone with this setup. Those runners look to be a straight shot to the valves. Can it be opened up to Max Wedge ports?
68 Cuda Notchback [Email]10.86@120[/Email]
69 Charger R/T 440/505
2009 Challenger SRT8
[Re: ChrgrCuda]
#2346542
08/01/17 02:42 AM
08/01/17 02:42 AM
AndyF
Dam. That's super slick. If I'd known that would possibly fit under my stock hood I'd gone with this setup. Those runners look to be a straight shot to the valves. Can it be opened up to Max Wedge ports? You would need to add weld material to the outside of the runners to make it big enough to work on a Max Wedge. The Pro Flo has really tiny ports out of the box. More show than go. I bet they work great once they are ported but I've never run one.
[Re: ChrgrCuda]
#2346549
08/01/17 03:16 AM
08/01/17 03:16 AM
ChrgrCuda
Texas, USA
Thanks Andy. After I receive my 337 intake from Summit I'll be sending it off to Wilson for the Max Wedge port work and having the bosses drilled for the injectors. I've been in contact with Rich and will be ordering the FAST XFI system thereafter. Thanks for the outstanding information from you and Rich.
[Re: ChrgrCuda]
#2346983
08/01/17 10:59 PM
08/01/17 10:59 PM
Posts: 625 Oakville, Wa
HOTMOPR
Oakville, Wa
I wanted a proflow but it only supports a 90mm TB. So ill be doing a elbow and hiding the coils down low beside the block.
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
[Re: ChrgrCuda]
#2347684
08/03/17 01:48 AM
08/03/17 01:48 AM
ChrgrCuda
Texas, USA
The 337 intake must be pretty popular. Summit revised the ship date from 8/4 to 8/14. Also went up on the price from about $250 to $377.
[Re: AndyF]
#2347843
08/03/17 01:27 PM
08/03/17 01:27 PM
ChrgrCuda
Texas, USA
Thanks Andy. If they revise them again I'll cancel my order and look hard at the Edelbrock pro flow intake.
