Re: 1967 to 1968 dart taillights?
[Re: moparvinson]
#2340725
07/21/17 12:30 AM
07/21/17 12:30 AM
Posts: 43,545 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
No, the 68 buckets will not fit, been there done that. 69 buckets do fit however.
JB Rhinehart, Realist
A-Body's RULE!
[Re: moparvinson]
#2342128
07/23/17 08:56 PM
07/23/17 08:56 PM
Rhinodart
Rhinotruck
Rhinotruck
I believe the 67-68 headlight brackets that are welded to the fenders are in a slightly different place so the grilles don't interchange either. You have to put 68 fenders on your 67.
A-Body's RULE!
[Re: UCUDANT]
#2345000
07/28/17 08:44 PM
07/28/17 08:44 PM
Rhinodart
Rhinotruck
Rhinotruck
I have some 68 Dart tailight lenses and bezels I don't need. I have plenty of them laying around too, but you need to install the buckets to put the lenses in and screw the bezels to or you will not have tail lights. To install those buckets you have to cut-out the 67 sheet metal that holds the buckets in and weld-in the 68 sheet metal.
A-Body's RULE!
