Big Block 727 Transmission Dipstick Question #2338747
07/17/17 11:57 PM
07/17/17 11:57 PM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
Is there supposed to be a depression in a big block dipstick tube near the port of the tube that connects to the transmission? Please reference the attached photos. I'm not sure if the was intended to prevent a rattle against the trans case or actual physical damage.
Re: Big Block 727 Transmission Dipstick Question [Re: vinnyd76] #2338755
07/18/17 12:03 AM
07/18/17 12:03 AM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Probably dented so it wouldn't rattle.
I will never use a stock tube and dip stick again after using the Mancini Racing locking dip stick. No more leaky dip stick tube.
Re: Big Block 727 Transmission Dipstick Question [Re: vinnyd76] #2338817
07/18/17 01:09 AM
07/18/17 01:09 AM
this
