Feedback on BB Victor heads using T&D rockers? #2338131
07/17/17 12:40 AM
07/17/17 12:40 AM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
Looking for users experiences with T&D rockers on Edelbrock BB Victor heads. My application would be street & strip with a .650"-ish solid roller and open spring load of 600+ #s.
I'll probably have more specific questions if I get some replies. Thanks - Brad
Re: Feedback on BB Victor heads using T&D rockers? [Re: BradH] #2338138
07/17/17 12:52 AM
07/17/17 12:52 AM
AndyF Online content
AndyF  Online Content
The T&D rockers that I have on my Trickflow 270 heads work great. They are accurate on the ratio, line up properly side to side, have high quality components and the scrub pattern looks excellent.
I do not have any experience with the Victor heads though so I guess I haven't really answered your question....
Re: Feedback on BB Victor heads using T&D rockers? [Re: AndyF] #2338381
07/17/17 02:43 PM
07/17/17 02:43 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
I have used both common shaft and individual shaft T&D's on Victor heads. If you will be using lash caps both need to be adjusted for shaft height. For the cost difference I prefer the individual shaft set up. For set up purposes they are less agravation.
Re: Feedback on BB Victor heads using T&D rockers? [Re: fbs63] #2676262
07/10/19 01:40 PM
07/10/19 01:40 PM
BradH Offline OP
BradH  Offline OP
Bringing this back from the dead... work
Re: Feedback on BB Victor heads using T&D rockers? [Re: BradH] #2676318
07/10/19 03:37 PM
07/10/19 03:37 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I have the T&D Victor rockers on my 440 Source heads. I know, not much help.
Re: Feedback on BB Victor heads using T&D rockers? [Re: CSK] #2676399
07/10/19 08:51 PM
07/10/19 08:51 PM
BradH Offline OP
BradH  Offline OP
No problem. How have they worked out?
Found a pic someone else posted years ago of the MW version (.725 intake offset vs .650).
Re: Feedback on BB Victor heads using T&D rockers? [Re: BradH] #2676596
07/11/19 03:31 PM
07/11/19 03:31 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
looks like photo from my original MW victors? I had Crower Ti Retainers on the springs.
I don't recall any issues with the rockers. Because I used +0.100" retainers, I think the retainer may have touched the inside of the rocker when the valve was closed. I used lash caps to get a bit of clearance.
I never measured the stock rocker stand height on the heads, and after having the issues with the stand cracking I just milled off the stands and used the max wedge type rocker shaft blocks. That allowed adjusting the stand height too in the amount the stands and blocks were machined.
I haven't seen the pared rocker shaft setup? It sounds nice, but I don't know how it is oiled?
Re: Feedback on BB Victor heads using T&D rockers? [Re: 451Mopar] #2676607
07/11/19 04:06 PM
07/11/19 04:06 PM
BradH Offline OP
BradH  Offline OP
Yep, I found that photo of yours on an old thread.
Re: Feedback on BB Victor heads using T&D rockers? [Re: BradH] #2676682
07/11/19 11:21 PM
07/11/19 11:21 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
so far 3000 miles & all is good.
Re: Feedback on BB Victor heads using T&D rockers? [Re: CSK] #2676745
07/12/19 09:33 AM
07/12/19 09:33 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
T&D single shaft rockers are limited to 1.550 diameter valve spring. I know guys clearance them or use other means of fitting them. Spend the money on the individual shaft versions. You won't regret it.
Re: Feedback on BB Victor heads using T&D rockers? [Re: fbs63] #2676784
07/12/19 11:41 AM
07/12/19 11:41 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
UNLESS YOU USE B3's geometry correction locators that move the rockers up & back from the valves.
Re: Feedback on BB Victor heads using T&D rockers? [Re: CSK] #2676804
07/12/19 12:45 PM
07/12/19 12:45 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I forgot to mention on the standard shaft setup, T&D uses a slightly smaller diameter shaft that is really thick walled. The #2, #3, and #4 stud hold downs are machined smaller where they align with the rocker shafts oil hole. A solid stud may cut off oil in the rocker shaft. As mentioned, if going high lift, stiff springs, the paired shaft setup is likely a stronger and more stable setup.
http://tdmach.com/product/big-block-mopar-edelbrock-440-victor-max-wedge-58-shaft-paired-system/
