Hi folks
I am about to stop using the factory trans oil cooler on my stock 4.7 2008 Dakota because one of the factory lines from trans to cooler disconnected by itself with almost disastrous results. My question is; how relevant is (flow or pressure vise) how high an aftermarket trans oil cooler is located on the vehicle relative to the transmission´s height? I have ample space in front of the radiator but I am concerned with height (probably 6" height from stock trans input/output lines on trans vs new cooler input/output lines location) as well as this new spot being too cool, especially in the wintertime.
Thanks for your input
Ragnar in Iceland
66 Charger, 451, .582" lift, 11" conv. 4.10:1. 4118 lbs 11.75@117 mph on regular Firestone Firehawk radials. Icelandic Champion in MC 2007, 2008, 2009 and 2022.
