Re: 440 black smoke from under car
[Re: 70runner]
#2337875
07/16/17 05:18 PM
07/16/17 05:18 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
black smoke is running rich.
bluish grey smoke is burning oil
white smoke (steam) is burning water/coolant
[Re: Supercuda]
#2337897
07/16/17 06:35 PM
07/16/17 06:35 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
I don't know about a rich idle. As the black smoke was seen while following the car. Maybe a miss fire. My guess, the carb. needs attention.
I have mechanical Aptitude. I can screw up anything.
[Re: 70runner]
#2337939
07/16/17 07:44 PM
07/16/17 07:44 PM
Posts: 2,872 Pattison Texas
CSK
Pattison Texas
PCV is clean, looks ok, rattles. Some oil puddles after sitting for awhile, and lower engine/trans area is pretty oily. Could this be the "smoke" after engine/trans warm up? pull a spark plug & see how it looks.
[Re: 70runner]
#2337941
07/16/17 07:46 PM
07/16/17 07:46 PM
bboogieart
Lost and Spaced
Quote"Some oil puddles after sitting for awhile, and lower engine/trans area is pretty oily." Heavy oil leak on hot pipes could be black. I don't mean to be a smart Alec but... Clean it up and solve your oil leak problem first, then see if your black smoke still there. You don't want to run low on oil looking for a problem that might not exist.
[Re: bboogieart]
#2337951
07/16/17 08:04 PM
07/16/17 08:04 PM
Posts: 18,160 Mass
DAYCLONA
Mass
Quote"Some oil puddles after sitting for awhile, and lower engine/trans area is pretty oily." Heavy oil leak on hot pipes could be black. I don't mean to be a smart Alec but... Clean it up and solve your oil leak problem first, then see if your black smoke still there. You don't want to run low on oil looking for a problem that might not exist. agreed, possible rear main seal/sending unit IMHO
[Re: DAYCLONA]
#2338096
07/16/17 11:38 PM
07/16/17 11:38 PM
Posts: 1,178 People's Republic of Kali
70runner
Quote"Some oil puddles after sitting for awhile, and lower engine/trans area is pretty oily." Heavy oil leak on hot pipes could be black. I don't mean to be a smart Alec but... Clean it up and solve your oil leak problem first, then see if your black smoke still there. You don't want to run low on oil looking for a problem that might not exist. agreed, possible rear main seal/sending unit IMHO No offense taken, you are correct...just trying to get a sense of how to tackle this. Rear main was recently replaced by daughter and boyfriend (heart surgeon who knows his way around engines). I removed 727 view plate and case/converter was pretty clean...wouldn't this area be soaked if rear main leaked? OTOH don't know where this much oil on the floor could come from except for the rear main.?. Sending unit area looks dry. There is about 50yrs of accumulated grime on the engine block, seaping areas on valve covers and oil pan. Probably need a good pressure wash, then some new valve cover/pan gaskets as a start. While I'm at it, decision to be made on whether to rebuild orig 440 given age and mileage. I guess some cylinder pressure checks would be a good start (along with checking the plugs).
[Re: 70runner]
#2338102
07/16/17 11:50 PM
07/16/17 11:50 PM
Posts: 96,666 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
Check to see if the seal around the trans dip stick is sealing, or leaking.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: amxautox]
#2338125
07/17/17 12:28 AM
07/17/17 12:28 AM
RapidRobert
As said I'd confirm/elim any external leaks. Might be a carb issue: leaking needle/seats or less likely partly waterlogged float(s). once any leaks are eliminated does it appear to be blue or black smoke (or both)?
[Re: RapidRobert]
#2338257
07/17/17 11:16 AM
07/17/17 11:16 AM
Posts: 2,537 God's Country Maryland
GODSCOUNTRY340
First thing to check would be the choke. If it's got a vacuum choke pull-off it may be blown. Wire the choke open and see if it clears up.
