Re: A ? for you cam guru's ant those running flat tappet cams.
[Re: rt66jim]
#2337791
07/16/17 02:33 PM
07/16/17 02:33 PM
Posts: 43,308 Bend,OR USA
Cab_Burge
How much pressure and RPM do you run when in race mode?
[Re: rt66jim]
#2337815
07/16/17 03:13 PM
07/16/17 03:13 PM
crabman173
crabman173
Often overlooked are the lifter bores themselves--first thing many do when a lobe goes flat is yank that now mushroomed lifter through the bore pulling it out the top--now you have a scratched--grooved--hurt lifter bore so you are doomed to repeat the trouble-- The BEST answer is a lifter bore ball- sizing broach- sold by Goodson --You hammer it through lifter bores and then slide hammer it back the other direction--sizes, smooths, and straightens lifter bores This is CRITICAL after an engine has been shoot peened as in AMPRO shot blasted for cleaning and we use it on every build--this goes a long way toward curing the issue--we have been using Lucas break in oil at over 3000 PPM ZDDP etc and it has been wonderful--cheaper than all the others as well Then...all the normal inners removed etc
[Re: rt66jim]
#2337855
07/16/17 04:39 PM
07/16/17 04:39 PM
Posts: 4,457 Washington
madscientist
Washington
I'm running .620 lift and a pretty fast lobe...similar to a Comp MM series and a double spring with 165 on the seat and IIRC 450 open when they were new.
I don't use anything special and I've never removed the inner spring. I use a QUALITY oil and keep the idle at 1k or a bit above.
Haven't had a flat lobe yet.
The only issue I've had was about 2004 or so and the lifters we were getting were junk. Lost 5-6 cams until I caught the issue.
At 19 runs its not a break in issue. If you had issues on start up, they show up right away.
[Re: rt66jim]
#2338000
07/16/17 09:33 PM
07/16/17 09:33 PM
Posts: 1,035 Missouri U.S.A.
71yelladustr
Missouri U.S.A.
I used Howard's direct lube lifters in my last 2 builds. One being a SB and the other a BB. Both engines have SFT Comp cams and have had no problems whatsoever. Lobes and lifters look great in both engines after 50+ runs. The Edm lifters leave a nice stripe of oil on the lobes just cranking the engine over. I run Valvoline VR1 in both engines fwiw.
392 gen III hemi on E-85 727 trans Dana 60 10.02@134
[Re: Cab_Burge]
#2338002
07/16/17 09:38 PM
07/16/17 09:38 PM
Posts: 4,002 Joplin, Mo
rt66jim
Joplin, Mo
How much pressure and RPM do you run when in race mode? 180 on the seat and 380 open. Shift @ 7000. No on EDM lifters.
[Re: rt66jim]
#2338369
07/17/17 02:28 PM
07/17/17 02:28 PM
fast68plymouth
So. Burlington, Vt.
To me it boils down to this.......
If you're running an aggressive flat tappet cam that requires a dual spring to maintain proper control of the valvetrain at high rpm's......... And you don't remove the inner spring for beak in....... And you have a problem with chopping a lobe prematurely......... It's just "shame on you" IMO.
This is in addition to making sure you are using the best break in lubes/oils, and have insured there is adequate lifter rotation prior to engine start up.
[Re: fast68plymouth]
#2338379
07/17/17 02:41 PM
07/17/17 02:41 PM
madscientist
Washington
This is in addition to making sure you are using the best break in lubes/oils, and have insured there is adequate lifter rotation prior to engine start up. I agree. The most important thing is getting the engine fired. Cranking on them is death. Then lifter rotation. Then oil. I'm getting ready to start another SFT engine in two weeks. 145 on the seat, 400 over the nose. I'm not pulling the inners out. I'm now convinced that I've said this publically I'm going to have this one go flat. I've got a known ignition and known carb. But I'm sure I'll get burned now just so fate can say it's made me eat my words.
[Re: rt66jim]
#2338503
07/17/17 06:04 PM
07/17/17 06:04 PM
Posts: 17,914 S.E. Michigan
ZIPPY
S.E. Michigan
I'm not a guru, I'm pretty much nobody and kinda like it that way.
What about lifter crown?
what do you do if the lobe taper seems right but lifter crown doesn't?
Who even takes a moment to try to look at lifter crown?
Waste of time? I've had a guru here pretty much say so, in the past. I disagree.
I have had the pleasure(?) of inspecting many, many lifters and cams on a pretty regular basis. Some new, some failed, some close to failure but not quite. During the time I was in that activity, I could not find any cams I honestly thought were made improperly. I sent many off to be tested...engineers a whole lot smarter than me, with diplomas and everthang (deliberately misspelled) ran multiple cams through the gamut of tests and there was never an issue found.
But I found many lifters that had either no crown at all, or barely enough to make the lifter rotate. At least a couple times a week, I'd find some that were flat or nearly so.
Not saying it's a 99 percentile killer or anything like that, but maybe it is worth a closer look than in the past.
On the last flat tappet hydraulic engine I did for myself, I went through 2 sets of lifters to find one set that I personally liked the looks of. And once I selected them, I didn't just use them! I took all of them apart, cleaned and oiled each one internally and reassembled. Waste of time, right? Lots of gray metal on the paper towels I used. Metal shavings visible in the solvent container. Good thing I'm not a high volume professional, I'd go broke doing that kind of thing.
Rich H.
Esse Quam Videri
[Re: rt66jim]
#2338541
07/17/17 07:06 PM
07/17/17 07:06 PM
crabman173
crabman173
I agree with Zippy A simple way to check for crown is set one lifter face against side of another lifter--hold to the light and Bingo--Now I have been in shops that made fixtures to check exact amount of crown but that was in bad old days of crappy oil etc An easy way to check lobe taper is check cam up in lathe and just run dial indicator across lobe--works like a dream I also take lifters apart if it is a high $$ critical build--I can't tell you how many have two metering discs--no metering disc, jelled up rust preventive--are full of wd40 so they are already pumped up etc Last week I had customer bring in s set of Cranes from the 70's in sealed box--Great I thought--parkerized faces--USA quality--I always do quick check by just depressing plungers with a pushrod etc and one lifter was almost solid--took it apart--two thick metering disc in bottom of lifter and none where it was supposed to be so.......run solids baby! I also have to say that the SBI lifters have been great and the Johnsons have been trouble all year long --I have seen four different engines have issues with them in one shop since Jan--not good and looks like the cheapo Summit cams come with SBI so that is a positive as that 6401 cam is a good piece for mild street I hate honing lifter bores the broach works like a dream on plain blocks and...let's face it no matter what all you do one fails every now and then just because
[Re: Cab_Burge]
#2338587
07/17/17 08:07 PM
07/17/17 08:07 PM
crabman173
crabman173
Yes they are that way--it is not much but usually like .002 range? Different makers do it their way but the taper on the lobe and the crown both work together to promote rotation You look through lifter bores at a Ford cam and the lobes are not centered on the lifters --another way to go even further on same idea
