Sta-Lube SL24239 API/GL-4 Multi-Purpose Hypoid Gear Oil #2337723
07/16/17 11:59 AM
07/16/17 11:59 AM
TC, Minnesota
Gabmando Offline OP
Gabmando  Offline OP
TC, Minnesota
Wondering if anyone had any negative experiences with this product?
This is for my 73 Charger Rallye 340CID 4 speed.
https://www.amazon.com/dp/B000M8RYMC/_encoding=UTF8?coliid=I3K36VGPZ1DHXP&colid=3T5O2FJHXMS9I
Thank you in advance for your feedback.
Re: Sta-Lube SL24239 API/GL-4 Multi-Purpose Hypoid Gear Oil [Re: Gabmando] #2338165
07/17/17 01:52 AM
07/17/17 01:52 AM
mt. pleasant, PA
Diplomat440 Offline
Diplomat440  Offline
mt. pleasant, PA
I've got it in my cars. No problems.
I get it at NAPA, but it's about $40 a gallon there.
Re: Sta-Lube SL24239 API/GL-4 Multi-Purpose Hypoid Gear Oil [Re: Diplomat440] #2338217
07/17/17 10:11 AM
07/17/17 10:11 AM
TC, Minnesota
Gabmando Offline OP
Gabmando  Offline OP
TC, Minnesota
Thank you for the feedback.
Re: Sta-Lube SL24239 API/GL-4 Multi-Purpose Hypoid Gear Oil [Re: Gabmando] #2338489
07/17/17 05:38 PM
07/17/17 05:38 PM
dogdays Offline
dogdays  Offline
The most important information on the jug is "GL-4". That means it does not contain the EP additives that will make your synchros less effective. Although I have to admit there must be a million trucks and cars running around with a GL-5 gear oil. But it's not optimal and can have very bad results.
So the GL-4 85W-90 looks like a good match for an old 4-speed.
R.
