Re: B Body Seat Belt ?
[Re: Casey]
#2337600
07/15/17 10:56 PM
07/15/17 10:56 PM
Posts: 16,163 Mesa, Arizona
dart4forte
Mesa, Arizona
There should be two small rivets holding the boot to the retractor. Once those are removed use a heat gun on the boot. Be careful not to overheat the boot. Once it becomes pliable it should slide off.
As a note you can use a hairdryer. Same holds true on getting the boot too hot.
Abe Lincoln
[Re: Casey]
#2337725
07/16/17 12:00 PM
07/16/17 12:00 PM
dart4forte
Mesa, Arizona
Don't see any rivets. Looks all original, just a rubber boot slid over the retractor mechanism. Heat gun might do the trick. dart4forte I see your in AZ ,so you know what the sun does to interior pieces out here. I think its just shrunk on tight? Has the color faded? If not it's probably ok. Just try the heat gun or hair dryer. As far as rivets, I went out to the garage and the 71 has rivets. Are you replacing the boot. If not and you are reprinting them make sure you use a good quality paint like SEM. Also make sure you use a good wax and grease remover. That paint will fisheye unless you get it super clean.
Abe Lincoln
[Re: Casey]
#2337806
07/16/17 02:58 PM
07/16/17 02:58 PM
Posts: 3,529 Lansing, MI
70gtx440dana
Lansing, MI
We have a board member Bill whom restores these. Drop him an email I bet he will offer assistance. Here is his website: http://www.allmoparseatbelts.com/
70 Road Runner 383-4 4 speed FJ5 & black guts 70 Charger R/T 440-4 4 speed FJ5 & white guts
[Re: 70gtx440dana]
#2337878
07/16/17 05:20 PM
07/16/17 05:20 PM
dart4forte
Mesa, Arizona
I work for Bill. I do his internet sales. When I send him cores that's how I remove the boots
Abe Lincoln
