Re: Voltage Regulator
[Re: 71birdJ68]
#2337545
07/15/17 08:10 PM
07/15/17 08:10 PM
Posts: 737 Michigan
BlueRacer69
They make a electronic regulator that looks kind of like a stock one. Agreed. They are inexpensive. You can pick one up on E-bay for around $17 or $18 bucks. Looks just like the original only electronic.
[Re: TOMRR]
#2337547
07/15/17 08:16 PM
07/15/17 08:16 PM
RapidRobert
it'll work, maybe for a period of time maybe forever. as said the spikes from the old type stresses the (electronic) ign system (to what extent I dont know, maybe slightly maybe more). since your RR ain't OE, you can get one (electronic) quickly/cheaply at your local parts house. EDIT there was a guy on here Mrrandy who was selling one that had the OE black cover with electronic guts for $29 to your door (iirc) and there was a parts house one that the black OE cover would reportedly fit but I dont remember the brand/part #. Wells 706 or 607 comes to mind but I dont remember if that was the one in question or just an electronic replacement that someone mentioned using at some point in time.
[Re: BlueRacer69]
#2337645
07/16/17 01:34 AM
07/16/17 01:34 AM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
They make a electronic regulator that looks kind of like a stock one. Agreed. They are inexpensive. You can pick one up on E-bay for around $17 or $18 bucks. Looks just like the original only electronic. Or if you want it really correct,use your original cover.Also the OE cover will fit almost all.
[Re: Cab_Burge]
#2338380
07/17/17 02:43 PM
07/17/17 02:43 PM
RapidRobert
The wells VR706 is a bolt in electronic replacement. it is half or less the "height" of the OE one (see eBay pic) & I used one way back & sounds like the OE black covers have a good chance of fitting onto it. I would purchase one which would get him going ASAP then see about locating an OE black cover. I may have one I'd send to you for the shipping.
[Re: Cab_Burge]
#2338650
07/17/17 09:59 PM
07/17/17 09:59 PM
RapidRobert
whichever one you get, If the black cover will fit it, be sure & post it.
