Yellow wire to starter relay 69 B body #2337445
07/15/17 05:02 PM
07/15/17 05:02 PM
Ks
P
pullandrag Offline OP
P
Ks
Yellow wire to starter relay 69 B body can somebody tell me what it does I tried to follow in in wiring diagram but my eyes crossed😣 I like to know what every wire does this one not sure thanks!
Re: Yellow wire to starter relay 69 B body [Re: pullandrag] #2337466
07/15/17 05:56 PM
07/15/17 05:56 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
terminal I goes to the ignitions switch
terminal S goes to the starter to engage it
terminal G goes the the neutral safety switch on Automatic cars or clutch
switch on manual cars (if equipped) or ground
terminal B goes to the positive battery post and bulkhead connector.
per the on line diagram I looked at the yellow wire goes to terminal I or the ignition switch via the bulkhead connector
Re: Yellow wire to starter relay 69 B body [Re: pullandrag] #2337517
07/15/17 07:19 PM
07/15/17 07:19 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The yellow wire is power from the ignition switch START terminal. (sends power to the relay with the switch in START position)
