71 Cuda p/s pump #2335189
07/11/17 09:59 AM
07/11/17 09:59 AM
MERRILLVILLE, INDIANA
sunroof446 Offline OP
I'm converting my 71 cuda 340 from manual to power steering. car is 340 4-speed with a 3.55 gear. what is the correct p/s pump saginaw or chrysler federal? I'm sure it is suppose to have a cooler also with the gear ratio. Thanks.
Re: 71 Cuda p/s pump [Re: sunroof446] #2335415
07/11/17 05:45 PM
07/11/17 05:45 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
federal w/cooler scope
Re: 71 Cuda p/s pump [Re: 6bblgt] #2335498
07/11/17 08:41 PM
07/11/17 08:41 PM
Thanks for the info.
Re: 71 Cuda p/s pump [Re: sunroof446] #2335511
07/11/17 09:06 PM
07/11/17 09:06 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Re: 71 Cuda p/s pump [Re: Alaskan_TA] #2336180
07/12/17 10:02 PM
07/12/17 10:02 PM
SE PA
cudaize Offline
cudaize  Offline
SE PA
I've found that 71 340 E-bodies with T/A gears typically have federal pumps with solid pulleys. The earlier cars with the standard ratio I have seen Saginaw pumps more than not.
Below is a picture of the pulley from my 340 71 cuda with 3/31 SPD
Re: 71 Cuda p/s pump [Re: sunroof446] #2336183
07/12/17 10:08 PM
07/12/17 10:08 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
What rear differential ratio?
Re: 71 Cuda p/s pump [Re: sunroof446] #2336412
07/13/17 10:47 AM
07/13/17 10:47 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
This is the pulley that is on my AAR.
Re: 71 Cuda p/s pump [Re: Alaskan_TA] #2336737
07/14/17 12:25 AM
07/14/17 12:25 AM
SE PA
cudaize Offline
cudaize  Offline
SE PA
The federal pump with the T/A gear is a 3.23 Open
Re: 71 Cuda p/s pump [Re: sunroof446] #2383990
10/08/17 05:21 PM
10/08/17 05:21 PM
Sacramento,California
JRepucci Offline
JRepucci  Offline
Any recommendations for a correct looking power steering hose? 340 w/Federal pump.
Re: 71 Cuda p/s pump [Re: JRepucci] #2386699
10/13/17 08:30 AM
10/13/17 08:30 AM
I ended up buying an nos one of ebay. I have not seen any reproductions that even come near correct. I checked ebay everyday until one came up.
Re: 71 Cuda p/s pump [Re: sunroof446] #2386701
10/13/17 08:55 AM
10/13/17 08:55 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
What did that NOS hose cost you.
Re: 71 Cuda p/s pump [Re: fastmark] #2386900
10/13/17 03:25 PM
10/13/17 03:25 PM
$175 on a buy it now.
