Re: 408 stroker with Milodon road race oil pan
[Re: Stanton]
#2336332
07/13/17 01:52 AM
07/13/17 01:52 AM
RapidRobert
^^^ that'd be my take. I ain't that far on mine (408) tho it does have 50 under rod bearings to destroke & (slightly) help deal with the tall pistons.
[Re: Fabman]
#2336450
07/13/17 12:41 PM
07/13/17 12:41 PM
Posts: 3,291 West Coast, USA
jbc426
West Coast, USA
The longer main studs can require some slight dimpling of the pan. There's a good post going on about this over at A-Bodies Only.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#2336592
07/13/17 06:01 PM
07/13/17 06:01 PM
Posts: 27,485 So Cal
autoxcuda
So Cal
The longer main studs can require some slight dimpling of the pan. There's a good post going on about this over at A-Bodies Only. Yes I had to check the main stud clearances of the main cap one from the rear, #4, under the center upkick in the pan when running a windage tray with main studs that had an adjustable height feature. Basically when there is extra bolt material sticking up past the nut that fastens the windage tray.
[Re: Fabman]
#2336597
07/13/17 06:09 PM
07/13/17 06:09 PM
autoxcuda
So Cal
Anyone out there running a 408 stroker engine with the Milodon road race oil pan?
I have heard conflicting comments on if this pan causes interference with the longer rods in the 408......
Thanks for any info that can be supplied..... I run the same 4" stroke as you with I beam scat rods. Not even close. The only thing would be the windage tray attachments that I described in post above
