Window Mechanism Lube
#2335585
07/11/17 10:58 PM
07/11/17 10:58 PM
Posts: 10,951 Spokane Valley, WA
Big Bad Bee
Spokane Valley, WA
I'm getting set to install my side windows and the quarter windows are in. What type of lube do you use to oil the mechanisms? What do you lube? Wheels and guides? Hinges/pivot points? Crank mechanism?
I’m listening.
Re: Window Mechanism Lube
[Re: Big Bad Bee]
#2335675
07/12/17 01:22 AM
07/12/17 01:22 AM
Posts: 7,197 Harrisburg, Pa.
screamindriver
Harrisburg, Pa.
I use sil glyde for all manual and power window mechanisms...Temps won't affect it and time won't harden it.. LINK Napa also carries it with their own label... Here's the lube chart for the quarter windows..
[Re: Big Bad Bee]
#2336885
07/14/17 12:57 PM
07/14/17 12:57 PM
Posts: 3,298 West Coast, USA
jbc426
West Coast, USA
I've had great success using synthetic disc brake lube on anything that slides, pivots, moves or glides. It wont attack plastic or rubber, resists washout and has all kinds of slippery stuff in it.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
