Re: Transmission gets stuck in park
[Re: jkwedge540]
#2335754
07/12/17 09:51 AM
07/12/17 09:51 AM
Posts: 516 ,Pa.
68dodge
,Pa.
I understand where you are coming from. These after market companies think they no everything. When you tell them the issue you are having, they thing us racers do not no what we are are talking about. Then if you do your on work, you are the one that cause the issue. Hope they make it right. I agree. CRT transmission still has not called or even PM me about the problem. What kind of service is that!
[Re: 68dodge]
#2336310
07/13/17 12:56 AM
07/13/17 12:56 AM
Posts: 11,692 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I understand where you are coming from. These after market companies think they no everything. When you tell them the issue you are having, they thing us racers do not no what we are are talking about. Then if you do your on work, you are the one that cause the issue. Hope they make it right. I agree. CRT transmission still has not called or even PM me about the problem. What kind of service is that! Nobody and no race part is 100% perfect 100% percent of the time. I probably wouldn't either.
[Re: J_BODY]
#2336346
07/13/17 02:18 AM
07/13/17 02:18 AM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
... I'd had that thing out on the bench to compare to John K's photo daayyyyssss ago! Doesn't need to go to the bench. Couple minutes pulling the valve body. The arm comes out with it.
[Re: CMcAllister]
#2336408
07/13/17 10:37 AM
07/13/17 10:37 AM
Posts: 13,202 aZLiViN
J_BODY
aZLiViN
... I'd had that thing out on the bench to compare to John K's photo daayyyyssss ago! Doesn't need to go to the bench. Couple minutes pulling the valve body. The arm comes out with it. that exactly what I meant referring to the pict of the two style park rods.... at this point no need to pull the trans.
[Re: 68dodge]
#2336462
07/13/17 12:58 PM
07/13/17 12:58 PM
Posts: 4,700 Wichita
GY3
Wichita
I understand where you are coming from. These after market companies think they no everything. When you tell them the issue you are having, they thing us racers do not no what we are are talking about. Then if you do your on work, you are the one that cause the issue. Hope they make it right. I agree. CRT transmission still has not called or even PM me about the problem. What kind of service is that! It is always nice when you email a vendor about a problem, show them pics of said problem and they ignore you. I know which vendor I WON'T be recommending anymore.
[Re: 68dodge]
#2336495
07/13/17 02:14 PM
07/13/17 02:14 PM
Posts: 11,725 Portage,michigan
B3422W5
Portage,michigan
Hate seeing John/ CRT take a beating on the internet like this. He sponsors a race at Norwalk on his dime every year for us Mopar racers. And i have seen him help guys with problems on his time for free when there was nothing in it for him except being a nice guy and wanting to help/ give advice so somebody could keep racing He is one guy who i think definately has definately earned the benefit of the doubt, if not more.
Sorry, rant over...
[Re: B3422W5]
#2336602
07/13/17 06:12 PM
07/13/17 06:12 PM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
Sorry, rant over... I AGREE
JAKES AUTOMOTIVE
[Re: bonefish]
#2336727
07/14/17 12:08 AM
07/14/17 12:08 AM
J_BODY
aZLiViN
ive had stock factory trans do the same thing when parked on a incline. mentioned that a ways back... the good book says to set the park brake and then shift to park. ...and this post doesn't sway my opinion of Mr. Cope. Met him once in Vegas, have ordered some small parts from him albeit quite a few years ago. Exchanged some diesel tech online... I have nothing against him or his product. I'm quite certain that if I called him out of the blue with a question or opinion that he'd oblige. ...and before we get into the "what if you spent the money" angle.... I've gone through my trans that had some issues and had it fail again (original from where I have no idea... was in the car when I got it from my dad), I've hauled it to probably the best torqueflight shop on the planet and had a weird failure. I'll either talk with them (texting picts etc..) and change stuff on my bench, or make the 4+ hour drive to drop it off with them. I've had my 727 in/out prob 4 time in the last two years. I think we finally have a handle on it, and I'm still confident that they've done everything in their power to fix this thing and I respect that to the end. I've spent good money on this thing and I'll continue to do so if need be. I know they're in my corner and treat them as such. still very curious to see what the park rod looks like. Take a deep breath... lets fix this thing!!
[Re: J_BODY]
#2337513
07/15/17 07:14 PM
07/15/17 07:14 PM
Posts: 25,967 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Measure from the pin to the end.
[Re: 68dodge]
#2337652
07/16/17 02:00 AM
07/16/17 02:00 AM
Posts: 2,771 Cedar Lake IN
CRT
Cedar Lake IN
I understand where you are coming from. These after market companies think they no everything. When you tell them the issue you are having, they thing us racers do not no what we are are talking about. Then if you do your on work, you are the one that cause the issue. Hope they make it right. I agree. CRT transmission still has not called or even PM me about the problem. What kind of service is that! You know dam will I am moving into a new shop. You could have called me but you have a bug up your ass. I will send you a 55 gallon drum filled with park rods if it makes u happy. No matter what u do, u cant make every one happy.
[Re: CRT]
#2337742
07/16/17 12:40 PM
07/16/17 12:40 PM
Posts: 516 ,Pa.
68dodge
,Pa.
219-374-0100 works from 9-6 M-F I called your number twice and left a message, Pm you 3 days ago and never answered. How do you do business with customers treating them like this. I will never buy another CRT transmission when you can not even put them together right. Plus A and A transmissions are made better. Plus they do not copy others parts like you do.
[Re: John_Kunkel]
#2337760
07/16/17 01:24 PM
07/16/17 01:24 PM
J_BODY
aZLiViN
8" it is... thanks JK. I suppose that pict is in the 70 service manual I have here. Diagram never caught my eye.
