Page 2 of 3 1 2 3
Re: Transmission gets stuck in park [Re: 68dodge] #2335480
07/11/17 08:10 PM
07/11/17 08:10 PM
usa,pa
jkwedge540 Offline
jkwedge540  Offline
usa,pa
I understand where you are coming from. These after market companies think they no everything. When you tell them the issue you are having, they thing us racers do not no what we are are talking about. Then if you do your on work, you are the one that cause the issue. Hope they make it right.
Re: Transmission gets stuck in park [Re: jkwedge540] #2335754
07/12/17 09:51 AM
07/12/17 09:51 AM
,Pa.
68dodge Offline OP
68dodge  Offline OP
,Pa.
I agree. CRT transmission still has not called or even PM me about the problem. What kind of service is that!
Re: Transmission gets stuck in park [Re: 68dodge] #2335997
07/12/17 04:07 PM
07/12/17 04:07 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I'd at least drop the pan and verify it has the correct rod in it. I learned years ago that in hot rodding things don't always go right and sometimes I have to bend some too.
Re: Transmission gets stuck in park [Re: 68dodge] #2336310
07/13/17 12:56 AM
07/13/17 12:56 AM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Nobody and no race part is 100% perfect 100% percent of the time.
I probably wouldn't either.
Re: Transmission gets stuck in park [Re: 68dodge] #2336324
07/13/17 01:29 AM
07/13/17 01:29 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
laugh2... I'd had that thing out on the bench to compare to John K's photo daayyyyssss ago!
Re: Transmission gets stuck in park [Re: 68dodge] #2336326
07/13/17 01:31 AM
07/13/17 01:31 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
It's a simple thing to pull the cable or rod out of the hole and see if the trans. shifts with nothing hooked to it. I've had cables that got too hot and would cause this issue.
Re: Transmission gets stuck in park [Re: J_BODY] #2336346
07/13/17 02:18 AM
07/13/17 02:18 AM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Doesn't need to go to the bench. Couple minutes pulling the valve body. The arm comes out with it.
Re: Transmission gets stuck in park [Re: CMcAllister] #2336408
07/13/17 10:37 AM
07/13/17 10:37 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
that exactly what I meant referring to the pict of the two style park rods.... at this point no need to pull the trans.
Re: Transmission gets stuck in park [Re: 68dodge] #2336462
07/13/17 12:58 PM
07/13/17 12:58 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
It is always nice when you email a vendor about a problem, show them pics of said problem and they ignore you. I know which vendor I WON'T be recommending anymore.
'63 Dodge 330
11.19 @ 121 mph
Re: Transmission gets stuck in park [Re: 68dodge] #2336495
07/13/17 02:14 PM
07/13/17 02:14 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Hate seeing John/ CRT take a beating on the internet like this. He sponsors a race at Norwalk on his dime every year for us Mopar racers.
And i have seen him help guys with problems on his time for free when there was nothing in it for him except being a nice guy and wanting to help/ give advice so somebody could keep racing
He is one guy who i think definately has definately earned the benefit of the doubt, if not more.
Sorry, rant over...
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Transmission gets stuck in park [Re: B3422W5] #2336602
07/13/17 06:12 PM
07/13/17 06:12 PM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
Sorry, rant over...
I AGREE
JAKES AUTOMOTIVE
Re: Transmission gets stuck in park [Re: B3422W5] #2336610
07/13/17 06:52 PM
07/13/17 06:52 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
ive had stock factory trans do the same thing when parked on a incline.
Re: Transmission gets stuck in park [Re: bonefish] #2336727
07/14/17 12:08 AM
07/14/17 12:08 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
mentioned that a ways back... the good book says to set the park brake and then shift to park.
...and this post doesn't sway my opinion of Mr. Cope. Met him once in Vegas, have ordered some small parts from him albeit quite a few years ago. Exchanged some diesel tech online... I have nothing against him or his product. I'm quite certain that if I called him out of the blue with a question or opinion that he'd oblige.
...and before we get into the "what if you spent the money" angle.... I've gone through my trans that had some issues and had it fail again (original from where I have no idea... was in the car when I got it from my dad), I've hauled it to probably the best torqueflight shop on the planet and had a weird failure. I'll either talk with them (texting picts etc..) and change stuff on my bench, or make the 4+ hour drive to drop it off with them. I've had my 727 in/out prob 4 time in the last two years. I think we finally have a handle on it, and I'm still confident that they've done everything in their power to fix this thing and I respect that to the end. I've spent good money on this thing and I'll continue to do so if need be. I know they're in my corner and treat them as such.
still very curious to see what the park rod looks like. Take a deep breath... lets fix this thing!!
Re: Transmission gets stuck in park [Re: 68dodge] #2337006
07/14/17 06:31 PM
07/14/17 06:31 PM
,Pa.
68dodge Offline OP
68dodge  Offline OP
,Pa.
The park rod does not seem to be the right one. Does not measure 8 3/16" for the 727. If this is the problem. Still waiting on CRT to call or PM.
Re: Transmission gets stuck in park [Re: 68dodge] #2337100
07/14/17 10:28 PM
07/14/17 10:28 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
well I dug around my immediate stash and only have the 904 one on the bench. Appears it measures 9 1/2" end to end.
Re: Transmission gets stuck in park [Re: J_BODY] #2337513
07/15/17 07:14 PM
07/15/17 07:14 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Measure from the pin to the end.
Re: Transmission gets stuck in park [Re: 68dodge] #2337652
07/16/17 02:00 AM
07/16/17 02:00 AM
Cedar Lake IN
CRT Offline
CRT  Offline
Cedar Lake IN
You know dam will I am moving into a new shop. You could have called me but you have a bug up your ass. I will send you a 55 gallon drum filled with park rods if it makes u happy.
No matter what u do, u cant make every one happy.
Re: Transmission gets stuck in park [Re: 68dodge] #2337653
07/16/17 02:02 AM
07/16/17 02:02 AM
Cedar Lake IN
CRT Offline
CRT  Offline
Cedar Lake IN
219-374-0100 works from 9-6 M-F
Re: Transmission gets stuck in park [Re: CRT] #2337742
07/16/17 12:40 PM
07/16/17 12:40 PM
,Pa.
68dodge Offline OP
68dodge  Offline OP
,Pa.
I called your number twice and left a message, Pm you 3 days ago and never answered. How do you do business with customers treating them like this. I will never buy another CRT transmission when you can not even put them together right. Plus A and A transmissions are made better. Plus they do not copy others parts like you do.
Re: Transmission gets stuck in park [Re: John_Kunkel] #2337760
07/16/17 01:24 PM
07/16/17 01:24 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
8" it is... thanks JK. I suppose that pict is in the 70 service manual I have here. Diagram never caught my eye.
Page 2 of 3 1 2 3
