Page 2 of 3 1 2 3
Re: B3 Racings's Indy EZ's & T&D rocker arm geometry correction [Re: BSB67] #2335220
07/11/17 11:15 AM
07/11/17 11:15 AM
USA
B3RE Offline
B3RE  Offline
USA
Originally Posted By BSB67
No one ever talks about the other half of the rocker arm geometry, as if it does not exist. Maybe it's un-important, although there seems to be no shortage of issue/failures on that side.
On the contrary, I talk about it all the time. But, it is the side that the geometry is designed into the rocker itself, which is why the OP is showing the custom B3RE/T&D rockers, so with off the shelf stuff, you correct what you can. The valve side being off will tear stuff up quicker than the pushrod side, so it is the higher priority.
Mike Beachel
I didn't write the rules of math nor create the laws of physics, I am just bound by them.
Re: B3 Racings's Indy EZ's & T&D rocker arm geometry correction [Re: fbs63] #2335225
07/11/17 11:19 AM
07/11/17 11:19 AM
USA
B3RE Offline
B3RE  Offline
USA
Originally Posted By fbs63
No way would I be confident with the shaft raised that far off the original pedestal and off center. If you want to correct it that much machine the mounts on the head flat and machine new mounting stands.
Over five years in production, and not a single failure to date. Some of those motors are in the low nines, and others have thousands of street miles. How many manufacturers have that kind of record?
Mike Beachel
Re: B3 Racings's Indy EZ's & T&D rocker arm geometry correction [Re: DoubleD] #2335235
07/11/17 11:33 AM
07/11/17 11:33 AM
USA
B3RE Offline
B3RE  Offline
USA
Originally Posted By DoubleD
Nothing new here - this method of raising the shafts up using an offset cam insert was tried more than thirty + years ago - you will eventually find that you will either pull or snap the studs out of the stands or push the whole shaft over - the more spring pressure the more the design flaw will begin to show. The solution thirty years ago was to machine the pads and make new blocks that were located and pinned to the head - yes it was pricey but it worked with lifts approaching .900. On a mild - low lift motor this method probably works fine - its an age old argument with a single shaft valve train as to rocker path - but there are many engines running T&D, Jesel, HS that are performing just fine. Its just a matter of personal choice
Thirty plus years ago, roller rockers for a Mopar were not all that prevalent, and .900" lift was unheard of in anything less than Top Fuel. As far as today, with today's technology and parts availability, who in their right mind would use a single shaft rocker system with 900" lift. Seriously!
Again, everything has its proper application, and I've done the blocks when necessary, or desired by the customer, and ZERO failures to date.
On a side note, I was supposed to have a set of the custom rockers at Carlisle this week, to compliment the Trick Flow 270's I will have on display. Unfortunately, T&D will not have them here in time, even though I ordered with plenty of time to spare. It would have been a good opportunity for show goers to check them out first hand.
Mike Beachel
Re: B3 Racings's Indy EZ's & T&D rocker arm geometry correction [Re: jbc426] #2335300
07/11/17 01:29 PM
07/11/17 01:29 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I'm apparently doing it wrong again...
Re: B3 Racings's Indy EZ's & T&D rocker arm geometry correction [Re: jbc426] #2335355
07/11/17 03:30 PM
07/11/17 03:30 PM
New York
polyspheric Offline
polyspheric  Offline
New York
The amount of anti-mid lift, in which the 50% lift does not occur at 90 degrees, is frequently used by OEM to improve the pallet (non roller tip)-to-stem wear properties. Heldt wrote a formula to calculate (some type of) anti-scuff by changing the pivot height, but it's over my head!
How much of the "error" (non 90 degree) you want on the pushrod side will vary somewhat between engines depending on other problems such as the horrible LA 14 degree difference between the 59 degree tappet, pushrod angle and 15 degree stem angle.
I'm working on a geo article now with a single shaft, but valves at different angles (no, it's not a poly - guess what?), so moving the shaft to improve the intake requires correction back the other way on the exhaust, blah.
The Gen-2 426 has its own problem: the rocker stands (both OEM and many aftermarket) are a single piece, which means any height adjustment (mill or shim) affects both valves simultaneously to the same distance, causing much hair to be pulled out!
Boffin Emeritus
Re: B3 Racings's Indy EZ's & T&D rocker arm geometry correction [Re: polyspheric] #2335371
07/11/17 03:51 PM
07/11/17 03:51 PM
USA
B3RE Offline
B3RE  Offline
USA
Originally Posted By polyspheric
The amount of scrub, in which the 50% lift does not occur at 90 degrees, is frequently used by OEM to improve the pallet (non roller tip)-to-stem wear properties. Heldt wrote a formula to calculate (some type of) anti-scuff by changing the pivot height, but it's over my head!
I'm working on a geo article now with a single shaft, but valves at different angles, so moving the shaft to improve the intake requires correction back the other way on the exhaust, blah.
You are absolutely correct. Different angles, with a common shaft, causes a lot of grief. The Gen 2 Hemi would need new stands made every time a change is made, to get everything right, hence the hair loss. The higher the stands, the closer the shafts would have to get together. That's why Barton's Hemi rockers are all individually mounted. They are pricey, but allow adjustability for each individual valve.
The poly heads would be even more of a headache, unless the stem heights were all set at the exact spec needed, on both intake and exhaust, to get the single shaft at the correct height for both. Then the rockers would have to be designed with the correct fulcrum length for the finished cylinder head. Change the valve length or tip height, do it all over again. Change the valve lift, do it all over again.....etc. Brace yourself, I think I see a bald spot.
Mike Beachel
Re: B3 Racings's Indy EZ's & T&D rocker arm geometry correction [Re: jbc426] #2335378
07/11/17 04:02 PM
07/11/17 04:02 PM
Washington
madscientist Offline
Washington
You read through this thread and you can see why Chrysler engines get virtually nothing in aftermarket parts, and what they do get is compromised junk.
Chrysler guys want a bolt on, good enough 30 years ago part. Then they talk like GM engines are snap together. Just bolt junk on and they make power.
None of that is true.
What is true in the number of Chrysler people who bolt on junk, then tell everyone they do it so it must be correct.
We get exactly what we deserve.
Re: B3 Racings's Indy EZ's & T&D rocker arm geometry correction [Re: jbc426] #2335431
07/11/17 06:22 PM
07/11/17 06:22 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Let me mention that, in addition to those unfortunate enough to experience actual failure, seizure, excess wear, etc. in valve gear, there are also less-than-perfect installations that may show no immediate signs of error but in which minor tweaks will provide more power, more stable high RPM, etc.
Whenever you have it apart, take a moment to analyze anything that "doesn't look right" (scuff marks, dissimilar wear patterns on stem tips, burned/blue pushrod balls and cups, fasteners that continue to loosen, valve adjustment that changes over time, etc.). Any anomaly is cause for inspection and discussion.
These archives contain a huge volume of experience, real world data, history of experiments, etc. well worth your time to research.
Boffin Emeritus
Re: B3 Racings's Indy EZ's & T&D rocker arm geometry correction [Re: Al_Alguire] #2335462
07/11/17 07:37 PM
07/11/17 07:37 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
Dont worry Al - I been doing it wrong for almost 40 years also - and yes roller rockers were available - common and used over 30 years ago and a 750 lift Crane R296 with custom HS 1.7 (yes they made them) got you close to an .850 lift - the idea was to keep the valve open at peak flow as long as possible - this was using iron heads with longer valves and 2' installed height - those were the days of innovation!
Re: B3 Racings's Indy EZ's & T&D rocker arm geometry correction [Re: jbc426] #2335521
07/11/17 09:25 PM
07/11/17 09:25 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Roller-tip rocker arms: 1928 Indian 101.
Boffin Emeritus
Re: B3 Racings's Indy EZ's & T&D rocker arm geometry correction [Re: polyspheric] #2335554
07/11/17 10:30 PM
07/11/17 10:30 PM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
https://en.m.wikipedia.org/wiki/Desmodromic_valve
Desmodromic valve control 1896. Interesting read. There is not much that has not been around for decades or even centuries.
Re: B3 Racings's Indy EZ's & T&D rocker arm geometry correction [Re: polyspheric] #2335561
07/11/17 10:37 PM
07/11/17 10:37 PM
So. Burlington, Vt.
fast68plymouth Online content
fast68plymouth  Online Content
So. Burlington, Vt.
I'm pretty sure Bentleys had them before that........along with ohc and 4 valves per cylinder.
Re: B3 Racings's Indy EZ's & T&D rocker arm geometry correction [Re: jbc426] #2335875
07/12/17 01:03 PM
07/12/17 01:03 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Question, how does the cross-section (looking down the shaft line) of a rocker change with increased ratios?
It would seem as it only can be done by shortening the pushrod side, or is there another method?
Thanks, Joe
Re: B3 Racings's Indy EZ's & T&D rocker arm geometry correction [Re: jbc426] #2335876
07/12/17 01:03 PM
07/12/17 01:03 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Oh I think I'm ok. This is definitely not anything new and a lot of ways to skin a cat
Re: B3 Racings's Indy EZ's & T&D rocker arm geometry correction [Re: fast68plymouth] #2335886
07/12/17 01:25 PM
07/12/17 01:25 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
did you ever see a 20's rols royce engine - everything had roller bearings even the mains - was a piece of machine artwork - unbelievable craftsmanship went into those engines
Re: B3 Racings's Indy EZ's & T&D rocker arm geometry correction [Re: madscientist] #2335896
07/12/17 01:42 PM
07/12/17 01:42 PM
West Coast, USA
jbc426 Offline OP
jbc426  Offline OP
West Coast, USA
Originally Posted By madscientist
Can you post a picture of the sweep pattern. The width is what's important. It's more important than having the pattern centered.
I tried to get some clear pictures of the rockers with the valve closed, open half way and all the way; but they did not come out well. I'll try again this weekend.
I also tried to set-up my dial indicator to measure the actual valve travel, but my set-up kept moving and messing up my readings. I'll see if my friend Roger a.k.a. Sxrxrnr, will bring his dial indicator set-up over this weekend to measure it accurately.
The cam specs for the new solid roller selected by Dwayne for my application are on this link at Comp Cams.
http://www.compcams.com/Company/CC/cam-specs/Details.aspx?csid=743&sb=2
I like running stock valve covers, and it looks as if I will still be able to with a bit more massaging of the internal baffles. I still get a kick out of telling people at car shows its basically all stock with headers, and then watch their faces when I fire it up with the electric cutouts open.
Re: B3 Racings's Indy EZ's & T&D rocker arm geometry correction [Re: jbc426] #2335913
07/12/17 02:02 PM
07/12/17 02:02 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Roller bearing crankshafts, another of those ideas that sound great, until:
1. they mention that the crank comes apart rather easily, sometimes in the middle of a trip
2. it increases the cost by a factor of 10
3. load capacity of roller vs. plain bearing: 6" mains and 4" rods would be a good start, it only worked because the engine turned low RPM and developed no power. Ask Enzo about roller cranks, but be walking away so he can't hit you
4. brain surgeon + many fixtures for assembly or service
5. rollers do not contain oil pressure, which means individual feeds from the pump to every journal, the crankcase looks like a subway line
6. very noisy, very difficult to diagnose problems
W. O. Bentley was respected as an engineer for his money.
Boffin Emeritus
Re: B3 Racings's Indy EZ's & T&D rocker arm geometry correction [Re: jbc426] #2335921
07/12/17 02:11 PM
07/12/17 02:11 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Talk about high tech in the most unusual places; bought a Honda string trimmer 15-odd years ago, 25cc 4 cycle engine, OHC!!
Joe
Re: B3 Racings's Indy EZ's & T&D rocker arm geometry correction [Re: jbc426] #2335926
07/12/17 02:15 PM
07/12/17 02:15 PM
New York
polyspheric Offline
polyspheric  Offline
New York
shortening the pushrod side: easiest and most common
is there another method: completely new rocker, keep the stock lever total length to retain vertical alignment with the stem and pushrod, but move the shaft toward the pushrods
E.g. my current project:
Total effective rocker arm length, adjuster to pallet: 3.40625"
Pushrod lever 1.375"
Valve lever 2.03125"
Ratio 1.477:1
New rocker with .158" offset center barrel:
Total effective length: 3.40625" (same)
Pushrod lever 1.2165"
Valve lever 2.1900"
Ratio 1.8:1
Boffin Emeritus
Re: B3 Racings's Indy EZ's & T&D rocker arm geometry correction [Re: jbc426] #2336027
07/12/17 05:23 PM
07/12/17 05:23 PM
USA
B3RE Offline
B3RE  Offline
USA
Might not be worth your time, John. Apparently, these rockers have been made before, which is odd, because I paid a custom charge to have T&Ds engineer draw up a NEW rocker profile to MY specs. Regardless, it's nothing new, and your free information has no value here. Go out and enjoy your car, because these guys already have it all figured out. Too bad they didn't tell us a long time ago.
Mike Beachel
Page 2 of 3 1 2 3
