TTI header fitment #2334886
07/10/17 07:36 PM
07/10/17 07:36 PM
South Park, Pa.
68LAR Offline OP
68LAR  Offline OP
South Park, Pa.
I may be looking for a new set of headers. Anybody have experience with TTI 2" or step headers in a '68 B body with RB engine? I'm looking for input on starter and Lakewood bell housing with 11" flywheel.. I read somewhere that a special starter was needed. I run a mini right now with old CPPA 2" headers and have no issues.
I also read that there may be an issue with clearance around the bell housing?
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: TTI header fitment [Re: 68LAR] #2334916
07/10/17 08:34 PM
07/10/17 08:34 PM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
They fit like a glove👍👍. How you use the same combo on all my cars. Lakewood bellhousing 11 inch clutch. Only thing is on the passenger side you will have to put a half moon notch in the bellhousing. It doesn't need to be very big......
68 cuda formula S 588" bb 5sp
70 CUDA CONVERT 500" 5SP (SUBLIME)
70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: TTI header fitment [Re: 68LAR] #2334919
07/10/17 08:37 PM
07/10/17 08:37 PM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
You need a special starter, they run right into a mini starter. Even in the inner position 10.5 flywheel. Other than that they are great.
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780#
69 Roadrunner 511 six pack 10.92 drive to track street car
Re: TTI header fitment [Re: 68LAR] #2334922
07/10/17 08:38 PM
07/10/17 08:38 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
I run the TTI 1 7/8 on my 70 Charger and no problems. They are close to the inner tie rod end at the idler arm but does clear.
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: TTI header fitment [Re: Old School] #2335008
07/10/17 10:55 PM
07/10/17 10:55 PM
South Park, Pa.
68LAR Offline OP
68LAR  Offline OP
South Park, Pa.
Old School,
What about the starter?
Re: TTI header fitment [Re: 68 HEMI GTS] #2335009
07/10/17 10:58 PM
07/10/17 10:58 PM
South Park, Pa.
68LAR Offline OP
68LAR  Offline OP
South Park, Pa.
Is this with a 2" tube?
Also what starter?
Why does Old School say that a special starter is not needed?
I'm confused!!!!!
Re: TTI header fitment [Re: 68LAR] #2335083
07/11/17 12:27 AM
07/11/17 12:27 AM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
Mine were 2" stepped. Just the normal mopar mini starter is what they hit.
Re: TTI header fitment [Re: 68 HEMI GTS] #2335119
07/11/17 01:22 AM
07/11/17 01:22 AM
southern Maryland
K
keefe Offline
keefe  Offline
K
southern Maryland
You might need to know what type head everyone has, raised ports vs. standard etc.
might explain the starter issues.
just a thought...
1971 duster twister 440, 3380#,509 M/P hyd,906's,full Exhaust,11.06@117.46 1/4,6.95@ 97.03 1/8,1.497 60ft.....
Re: TTI header fitment [Re: 68LAR] #2335167
07/11/17 04:16 AM
07/11/17 04:16 AM
Massillon, Ohio
cudatom Online content
cudatom  Online Content
Massillon, Ohio
The TTI stepped headers and a bdody are tight on the starter. Mine had 1/8 clearance maybe less.
Was concerned that the heat would be an issue so I used DEI heat shield around the pipe. Going on 3 yrs now and no starter problems.
My heads are Eddy Performers.
Ok
Re: TTI header fitment [Re: keefe] #2335230
07/11/17 11:28 AM
07/11/17 11:28 AM
South Park, Pa.
68LAR Offline OP
68LAR  Offline OP
South Park, Pa.
just a thought...
Good thought.. I'd be using Eddy RPM heads with angled spark plug. This is the info I'd be more interested in. I guess I should have added that info at the beginning, sorry!
Lets narrow things down a bit.
2" tubes, Eddy RPM heads with angled plugs, RB block, 11" flywheel with Lakewood bell housing, in a '68 B body. I think that covers it?????
Re: TTI header fitment [Re: 68LAR] #2335306
07/11/17 01:42 PM
07/11/17 01:42 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
just a thought...
My old 65 Plymouth B body had a 440 with angled plug Edelebrock 84 cc heads, 2 inch TTI headers. I just used a mini starter off a 93 dodge 360 magnum engine. The only thing I had to do is take off the electrical terminal adapter. Didn't have to dent any header tubes etc to get the starter to fit. I ran a 727 auto trans. So I cant answer about the bell houseing/ flywheel
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: TTI header fitment [Re: 68LAR] #2336369
07/13/17 06:44 AM
07/13/17 06:44 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I run the TTI 2" headers and they fit great. Mine is an auto and I use a mini starter. Ron
Re: TTI header fitment [Re: 383man] #2337716
07/16/17 11:45 AM
07/16/17 11:45 AM
South Park, Pa.
68LAR Offline OP
68LAR  Offline OP
South Park, Pa.
A little bump here.
Are there no more inputs on these 2" headers in a stick car application with a 11" flywheel? I'm really concerned with the starter issues. Some say it works, some say it doesn't, very confusing. Can't see spending $740 for headers and another $240 for a starter. Tooo rich for my blood!!!
Re: TTI header fitment [Re: 68LAR] #2337743
07/16/17 12:44 PM
07/16/17 12:44 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I had to notch my Lakewood's flange on the passenger side with the 2" RB, TTI's. All the bolts that clamp it to the block saver plate are unaffected, as it didn't go beyond that radius.
This combo goes in my '70 E-Body, but the fitment on the engine trans should be the same. I can take some pictures if you want to see where I trimmed exactly.
Not an issue unless you need to get the car inspected during tech, and then they may not notice it. Any modifications to the scatter shield do affect the SFI rating unless signed off by lord knows who.
Re: TTI header fitment [Re: 68LAR] #2337757
07/16/17 01:16 PM
07/16/17 01:16 PM
Suffolk County, New York
1mean340 Offline
1mean340  Offline
Not the same application but I was a little upset with fitment of my 1 7/8th TTI headers for my LA ebody. The headers looked great, I ordered the polished ceramic which had a show quality look to it. Only issue was the driver's side flange bolt holes weren't even close to lining up, the forward most primary tube's holes were about 1/4 inch or more off. It was pretty obvious when putting the header gasket up against the header flange. I had to cut the flange before the #1 primary tube and pull the tube forward quite a bit to get the holes and tube to line up with the port. Not the end of the world, but not something I've ever had to do on high end headers. Everything else fit pretty good and the passenger side flange was fine.
Re: TTI header fitment [Re: 68LAR] #2337828
07/16/17 03:33 PM
07/16/17 03:33 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
400 with Edelbrock heads in an A-body here. The starter was the LEAST of the fitment problems. They fit but take up a LOT of room and everything in the general vicinity is a pain to get to. TTI has really good charts and diagrams on their website telling you what headers fit with what equipment.
Re: TTI header fitment [Re: Dave Hall] #2338004
07/16/17 09:41 PM
07/16/17 09:41 PM
South Park, Pa.
68LAR Offline OP
68LAR  Offline OP
South Park, Pa.
Bin on their web site and they do say for my application, I will need that special starter...
Re: TTI header fitment [Re: 68LAR] #2338278
07/17/17 11:43 AM
07/17/17 11:43 AM
mn.
taxidermy man Offline
mn.
Just finished installing 2" TTI's on a 69" charger, 11" flywheel,first attempt was with my Dakota mini starter...No go, bit the bullet and bought a Robbmc starter, plenty of room around starter and everywhere else. Bought these headers used for a good price so that justified paying the money for the new starter.
Re: TTI header fitment [Re: 68LAR] #2338672
07/17/17 10:26 PM
07/17/17 10:26 PM
Virginia
HemiStan Offline
HemiStan  Offline
Virginia
Here is some info for you. Maybe some of it can help. I have used TTI headers on several cars. Here are two:
1969 Super Bee. 440, 4 speed, 11" flywheel, cast iron bellhousing, TTI 1 7/8" headers, Carquest/Advanced Auto starter (part number 17466SN).
1966 Satellite. 426 Hemi, 4 speed, 11" AND the 10 1/2" flywheels, Lakewood bellhousing, TTI 2 1/4" headers, Carquest/Advanced Auto starter (part number 17466SN).
Everything fit beautifully on the Super Bee. No modifications necessary.
I did have to modify the Lakewood on the RH side to fit the headers (as per the TTI instructions). Everything else fit perfectly.
The starter I listed fits and works great. Super small and super strong.
Stan
