Page 1 of 3 1 2 3
RHS INDY 360X heads!! #233486
02/23/09 12:40 AM
02/23/09 12:40 AM
Buenos Aires, ARGENTINA
madmax2 Offline OP
madmax2  Offline OP
http://www.compperformancegroupstores.co...egory_Code=Chry
What thinks about this heads? some experience?
'70 Dodge GTX sb 418ci (Early A-body),
Lunati Solid cam 270°/243°@.050/.548", Edelbrock Heads, Weiand X-CELerator,
Holley Terminator EFI, Tremec 6 sp manual, 3.90:1, TTI Headers.
Re: RHS INDY 360X heads!! [Re: madmax2] #233487
02/23/09 12:46 AM
02/23/09 12:46 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Except the new bosses added for dual ex patterns and dual rocker set up they look exactly like the RHS heads I just sold. Those were VERY nice castings, machining and casting quality was great. Ports were very well thought out and way better than a regular magnum head. I think they are the best iron head short of a W2.
Re: RHS INDY 360X heads!! [Re: HotRodDave] #233488
02/23/09 02:53 AM
02/23/09 02:53 AM
SoCal
Brian Hafliger Offline
SoCal
I plan to get a pair real soon and do some work to them. I'll post info and pics as soon as I do. Hopefully we can do an engine with them and get some HP #'s as well!
Brian
Brian Hafliger
Re: RHS INDY 360X heads!! [Re: Brian Hafliger] #233489
03/03/09 04:37 AM
03/03/09 04:37 AM
madmax2 Offline OP
madmax2  Offline OP
Brian
I will stay waiting... good luck
Re: RHS INDY 360X heads!! [Re: madmax2] #233490
03/03/09 11:10 AM
03/03/09 11:10 AM
SoCal
SoCal
Those heads will probably be here at the end of March or early April...
Brian
Re: RHS INDY 360X heads!! [Re: Brian Hafliger] #233491
03/03/09 12:09 PM
03/03/09 12:09 PM
central Pa.
71Pan Offline
71Pan  Offline
central Pa.
Looks like a great head. But why can't somebody bring out a head with a least 210 cc port volume.
I look at all sbc stuff and want to stick a fork in my eye.
Re: RHS INDY 360X heads!! [Re: Brian Hafliger] #233492
03/03/09 12:26 PM
03/03/09 12:26 PM
land of 10,000______'s
BDS871Cuda Offline
BDS871Cuda  Offline
I ran X heads on a 340 years ago, they made good power.
I don't think they will do as good as RPM heads,
but for $770 for new castings, you can't go
wrong.
They say 550 HP. I would bet it would have to be
a stroker with max porting.
Still a good deal.
Snap your neck, mega G-force launch, is all I want!
Re: RHS INDY 360X heads!! [Re: BDS871Cuda] #233493
03/03/09 01:29 PM
03/03/09 01:29 PM
North Dakota
Jesse_Lackman Offline
super gas
super gas
North Dakota
550 would be possible, I got 520 with a 236/242 cam;
Street 360/408 dyno results (520 CHP - 540 CTQ)
Re: RHS INDY 360X heads!! [Re: BDS871Cuda] #233494
03/03/09 01:38 PM
03/03/09 01:38 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
Jesse Lackman made 520hp/548 tq IIRC on a 408 with some far from maxed out RHS 360HPST heads and a mildish (238@.050) hydraulic roller. the 360HPST heads were the starting point for these heads.
here's a link to Jesse's engine thread
dang it, looks like Jesse beat me (:
about the only things these have in common with OEM "X" heads are the name and the fact they're iron......
2017 Grand Cherokee Overland
Re: RHS INDY 360X heads!! [Re: HotRodDave] #233495
03/03/09 01:41 PM
03/03/09 01:41 PM
North Dakota
super gas
super gas
North Dakota
I didn't think of the dual ex pattern when I made my suggestions for the 360HPST to RHS a couple years ago, nice addition. I'd still like to see a version with the pushrod holes un machined or machined for offset rockers.
Re: RHS INDY 360X heads!! [Re: Jesse_Lackman] #233496
03/03/09 02:19 PM
03/03/09 02:19 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
wow, those were incredible numbers. Im running a hughes solid cam in my 416 that is the 245/250 @ .050. my TA heads have been obscenely ported as well.
i want too know what secrets you put into that motor (i never dyno'd mine).
What would you shift that (or my motor) at if hughhes says its good to 6100 rpm?? Ive been hitting it at 6500.
Re: RHS INDY 360X heads!! [Re: aarcuda] #233497
03/03/09 08:38 PM
03/03/09 08:38 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Guys Guys Guys these heads are not the X heads we have had around for the last 41 years!
Flow is better out of the box both in terms of volume and quality of the air flow. The combustion chamber is WAY better than an X head. It has genourous quench areas no funky divots and the RHS has way better swirl and wet flow characturistics. Even if the X head was ported to make as much flow as a RHS head it still will not make as much power.
Re: RHS INDY 360X heads!! [Re: HotRodDave] #233498
03/03/09 10:57 PM
03/03/09 10:57 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
my heads are ported pretty nice. Mullin ported them for me back in the 80's when he had a shop out in the LA area.
Re: RHS INDY 360X heads!! [Re: aarcuda] #233499
03/03/09 11:05 PM
03/03/09 11:05 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
and
Re: RHS INDY 360X heads!! [Re: aarcuda] #233500
03/03/09 11:22 PM
03/03/09 11:22 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
aar How do your heads flow?
Getting old just means you were smarter than some and luckier than others.
Re: RHS INDY 360X heads!! [Re: dannysbee] #233501
03/03/09 11:45 PM
03/03/09 11:45 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
you got me there. I didnt pay to get them flowed. But I asked for the best he had and he said I got it. I have some other pictures but theyre at work. the pushrod hump is nonexistent. the valve guides in the port is thinned and tapered. looks really nice.
I should have had them flowed but he told me not to waste my money cause he's flowed these before. i can remember any more than that
Re: RHS INDY 360X heads!! [Re: aarcuda] #233502
03/04/09 08:48 AM
03/04/09 08:48 AM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
these were taken after the heads had sat for a number of years. sorry for the rust.
Re: RHS INDY 360X heads!! [Re: aarcuda] #233503
03/04/09 08:49 AM
03/04/09 08:49 AM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
and this
Re: RHS INDY 360X heads!! [Re: aarcuda] #233504
03/04/09 08:52 AM
03/04/09 08:52 AM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
and here
Re: RHS INDY 360X heads!! [Re: aarcuda] #233505
03/04/09 08:54 AM
03/04/09 08:54 AM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
exhaust
Page 1 of 3 1 2 3
