Re: car will only start when releasing key to run position?
[Re: Supercuda]
#2334470
07/10/17 01:25 AM
07/10/17 01:25 AM
Posts: 6,098 Valencia, España
NachoRT74
Valencia, España
actually, I had 11 volts in both crank and run on both sides of the ballast.
I thought that was weird. Having the same voltage on both sides of the ballast during start is normal. Actually not. While cranking the run circuit power should decay the same ammount than the coil source in run. That's why the brake light ( and oil if equipped ) on cluster dimms out while cranking, they are on Run circuit
[Re: 72 RR DUDE]
#2334471
07/10/17 01:28 AM
07/10/17 01:28 AM
NachoRT74
Valencia, España
Wire's are back words on the ballast resister. There is no a way to conect backwards a resistor
[Re: 1971 Gran Coupe]
#2334548
07/10/17 08:51 AM
07/10/17 08:51 AM
Posts: 668 Hamburg, Pa.
72 RR DUDE
Hamburg, Pa.
I restored a 72 RR that did the same thing and I did have the wires back words they only push on.An old time Mopar mechanic told me what was wrong. That,s how I know!Maybe you can,t on his year car but you could mix them in 72
[Re: pyp1000]
#2334559
07/10/17 09:45 AM
07/10/17 09:45 AM
Posts: 4,287 Morrow, OH
markz528
Morrow, OH
Again, you are not supposed to run a ballast resistor with the MSD. If you have been getting away with it, so be it, but I can tell you my car would barely run when I had the ballast resistor in the circuit with the 6AL2. First thing the MSD tech asked me was did I remove the resistor!
Sounds like you are not getting power on the small red wire during cranking. As I stated before, you need to temporarily jump that wire to the battery and see if that solves the problem.
I suspect that you have the small red wire connected to the ballast resistor wiring which (again) is not getting power while cranking due to a bad bulkhead. There is theoretically nothing wrong with doing it that way and long as you provide power during cranking and run.
The small red wire requires full battery power to run the box.
[Re: pyp1000]
#2334565
07/10/17 10:14 AM
07/10/17 10:14 AM
markz528
Morrow, OH
The bulkhead connector in question is wire J3 connector pin D. J3 is a #14 AWG brown wire and should be the top left corner (top row of connectors all the way to the left).
You can stick a voltage probe in that connector while cranking and see if you have full battery voltage. You can also remove the plastic connector and inspect the connections.
Or you can do what I suggested up and jumper that wire for testing............
[Re: markz528]
#2334569
07/10/17 10:32 AM
07/10/17 10:32 AM
NachoRT74
Valencia, España
The small red wire requires full battery power to run the box. False, the small red wire is just a remote on signal, and works perfectly with the ballast source originally made for the stock coil wiring setup. Its on owner choose keep it or not. Old MSD instructions sheets said the need to remove and splice wires together ( or whichever method you preffer to use to bypass ballast ), but laters instruction sheets were updated and specifically says the coil + lead wire can be used for that signal even with the balast still on firewall. Where the ballast needs to be removed is on RTR distributors, because they don't have the power source separated like the modules get
[Re: pyp1000]
#2334573
07/10/17 10:43 AM
07/10/17 10:43 AM
Posts: 1,645 Phila. Pa.
Mattax
Phila. Pa.
What Nacho wrote. On a 6A 6C or 6T the small red wire draws a 1/4 amp at 12 volts. It just needs enough power to keep the transistorized relay on. It will work below 12 volts, although there is limit - it won't work at 5 volts. Obviously it will work above 12 volt and draw even less current.
Last edited by Mattax; 07/10/17 11:06 AM. Reason: revised to make sense as Nacho was faster to the draw.
[Re: NachoRT74]
#2334579
07/10/17 10:55 AM
07/10/17 10:55 AM
markz528
Morrow, OH
False, the small red wire is just a remote on signal, and works perfectly with the ballast source originally made for the stock coil wiring setup. Its on owner choose keep it or not. Old MSD instructions sheets said the need to remove and splice wires together ( or whichever method you preffer to use to bypass ballast ), but laters instruction sheets were updated and specifically says the coil + lead wire can be used for that signal even with the balast still on firewall. Where the ballast needs to be removed is on RTR distributors, because they don't have the power source separated like the modules get [/quote] I know exactly what the small red wire does. Do what you want................. I'm done with my input.
[Re: markz528]
#2334588
07/10/17 11:08 AM
07/10/17 11:08 AM
NachoRT74
Valencia, España
My friend, I'm not trying to be a smartass, just posting what diagrams say, and it says straight from coil just like it is. Using mag dist
[Re: pyp1000]
#2334597
07/10/17 11:20 AM
07/10/17 11:20 AM
NachoRT74
Valencia, España
Thanks Mattax
Is just abouth some myths needing to be busted
[Re: NachoRT74]
#2334607
07/10/17 11:29 AM
07/10/17 11:29 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
I thought that was weird. Having the same voltage on both sides of the ballast during start is normal. Actually not. While cranking the run circuit power should decay the same ammount than the coil source in run. That's why the brake light ( and oil if equipped ) on cluster dimms out while cranking, they are on Run circuit Put a meter on it and come back with your results.
[Re: NachoRT74]
#2334736
07/10/17 02:51 PM
07/10/17 02:51 PM
Posts: 15,498 Omaha Ne
TJP
Omaha Ne
Wire's are back words on the ballast resister. There is no a way to conect backwards a resistor hey Nacho, If one hooks a resistor up backwards it will become a compliant circuit RIGHT ??? Sorry couldn't resist (no pun intended)
[Re: pyp1000]
#2334990
07/10/17 10:31 PM
07/10/17 10:31 PM
Posts: 3,392 St. Charles, MO
wingman
Uncreative Title
Uncreative Title
St. Charles, MO
Whew. It looks like I have my work cut out for me. The cam sensor in my daily driver went bad so I have to get that fixed first.
It may take me a day or so to start the trouble shooting that you all have suggested.
I will keep you updated. Unhook the white wire--do not use it. Unhook the ballast resistor--do not use it. Then twist your "start" and "run" circuit wires together and hook them to the small red. Fixed. This is the simplest way to run an MSD in a Mopar, but for some reason sometimes people make it complicated. The MSD instructions could be clearer, I guess...
1969 Dodge Coronet Super Bee 383 A4 1970 Plymouth Road Runner 440 FC7 (sold)
