Re: car will only start when releasing key to run position?
[Re: pyp1000]
#2334326
07/09/17 09:18 PM
07/09/17 09:18 PM
RapidRobert
if it ran before, then you have it wired right, yes you might have jostled something loose or it might just be Murphys Law that a connection worked loose at the same time as the intake swap. Pull the wire/terminal off of the "ign" male terminal on the starter relay to disable the starter then have a helper hold the key to "start" & you under the hood with your meter see if the coil and MSD are both being fed.
[Re: pyp1000]
#2334337
07/09/17 09:34 PM
07/09/17 09:34 PM
Posts: 4,920 Joplin, MO USA
Robbins
Joplin, MO USA
Try replacing the the pickup in the dizzy. Are you using a stock dizzy or MSD? I've had this issue with an 81 swb pickup with stock dizzy.
Moparlee
[Re: RapidRobert]
#2334338
07/09/17 09:35 PM
07/09/17 09:35 PM
Posts: 4,280 Medford OR
FrankenScamp
Medford OR
Also I've found that just because something is new, doesn't mean it's good. These things can be frustrating. Good luck. Let us know what you find.
[Re: RapidRobert]
#2334346
07/09/17 09:55 PM
07/09/17 09:55 PM
Posts: 857 charlotte,nc
pyp1000
charlotte,nc
can you tell me exactly where to put the test leads to check for coil and msd spark?
I pulled the wire from starter relay as requested.
I then pulled the coil wire and Had helper turn ignition key to start and then release to run. Somewhere along that time period, I got the ever-loving snot shocked out of me. My right hand is still tingling.
[Re: pyp1000]
#2334369
07/09/17 10:42 PM
07/09/17 10:42 PM
Posts: 21,822 Kirkland, Washington
Pacnorthcuda
any particular thing I should be checking at the bulkhead connector? Yes, disconnect it it from the engine side and inspect, you are looking for signs of heat/burning/melted plastic etc. Clean corrosion if evident. Reconnect and try. You can also check for voltage at the ballast resistor while cranking--I bet there is none, but it IS there when you release the key to the run position.
[Re: pyp1000]
#2334396
07/09/17 11:23 PM
07/09/17 11:23 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
actually, I had 11 volts in both crank and run on both sides of the ballast.
I thought that was weird. Having the same voltage on both sides of the ballast during start is normal.
[Re: pyp1000]
#2334400
07/09/17 11:28 PM
07/09/17 11:28 PM
Posts: 4,270 Morrow, OH
markz528
Morrow, OH
So I assume that you are using a Mopar electronic ignition?
I agree with the bulkhead as being a strong suspect.
I also assume that you have a ballast resistor with just 2 wires. Without removing the ballast resistor wires, I would run a jumper from the positive side of the battery to the ballast resistor (end that has 2 wires connected to it) then try to start it.
If it fires while cranking, then it does point to a bad bulkhead connector. I suspect it will fire.
Unless I'm worried about full originality, I splice wires on both sides of the bulkhead for both the high amperage wires. I remove the brass connectors, run a drill through the plastic connectors and just run the wires straight through. Have done this on a couple cars now very successfully.
[Re: markz528]
#2334401
07/09/17 11:35 PM
07/09/17 11:35 PM
markz528
Morrow, OH
I reread your post and see that you are runnimg the MSD. With most MSDs you should not have a ballast resistor.
Where are you powering your MSD from?
I would still do what I suggested in my post above, but to the MSD power wire.
I do suspect that the way you have the box powered you are losing voltage to the MSD because of a bad connection in the bulkhead. I suspect that the MSD power is being taken off of the original ballast wiring.
PM me if you would like some additional guidance.....
[Re: pyp1000]
#2334419
07/09/17 11:58 PM
07/09/17 11:58 PM
Posts: 1,645 Phila. Pa.
Mattax
Phila. Pa.
Hand hurt? Be thankful its not worse (yes it can be). Look at the MSD 6 instructions for how to test. Try not to do a traditional spark wire test with any MSD unless you must. Ignition power during start uses the wire connected to the coil side of ballast resistor. In other words, it comes from the starter switch bypassing the resistor. IIRC if that's not working with the MSD the MSD isn't getting turned on. Disconnect the battery and check for connectivity between the battery supply and the start side of the ballast (resistance if using a meter, light on if doing it that way). If not, then go to the back of the switch to determine if its switch or wiring. If you prefer diagrams, here's my '67 Barracuda charging and ignition wiring diagram Your colors may be different but the layout will be similar.
[Re: Mattax]
#2334432
07/10/17 12:12 AM
07/10/17 12:12 AM
pyp1000
charlotte,nc
Hand hurt? Be thankful its not worse (yes it can be). Look at the MSD 6 instructions for how to test. Try not to do a traditional spark wire test with any MSD unless you must. Ignition power during start uses the wire connected to the coil side of ballast resistor. In other words, it comes from the starter switch bypassing the resistor. IIRC if that's not working with the MSD the MSD isn't getting turned on. Disconnect the battery and check for connectivity between the battery supply and the start side of the ballast (resistance if using a meter, light on if doing it that way). If not, then go to the back of the switch to determine if its switch or wiring. If you prefer diagrams, here's my '67 Barracuda charging and ignition wiring diagram Your colors may be different but the layout will be similar. Yep. Hand is still tingly. Thank you so much for the easy to understand diagram. I am going to use this as I trace down my wiring.
