2009 Chrysler Minivan Code P0303 cylinder misfire #2333751
07/08/17 07:03 PM
07/08/17 07:03 PM
Klamath Falls, Oregon
Dartslantsix Offline OP
2009 VW Routan AKA Chrysler minivan with 3.8L v6. 113K miles
Couple weeks ago code P0303 popped up so I replaced the plugs and wires. I used the Champion double platinum that came stock on this engine. The light went away and we've been driving it with no issues.
This morning my wife says it did a "rough start" and it popped the same code again with the light on. Van is running great otherwise.
What else can I check?
Thanks.
Re: 2009 Chrysler Minivan Code P0303 cylinder misfire [Re: Dartslantsix] #2333766
07/08/17 07:35 PM
07/08/17 07:35 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Is that code for #3 cylinder? If you can't duplicate the problem enough to accurately diagnose it, then you might just have to throw parts at it until you hit the right one. With no other codes, I would try a coil pack and then swap the injector. You should do a compression check, but if the problem is intermittent, that doesn't seem likely.
What does that plug look like now?
Master, again and still
Re: 2009 Chrysler Minivan Code P0303 cylinder misfire [Re: Dartslantsix] #2333952
07/09/17 08:34 AM
07/09/17 08:34 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
My mother has a 2005 3.3 T&C.
I have had problems three times with new RE14PLP5 Champion double platinums quickly going bad by losing the welded-on tiny platinum discs.
I finally did away with using the OEM plugs with
NGK LZTR5AIX-13/2314 Iridium plugs
and the problems went away.
On the 2005 there was also a TSB indicating that some OEM coil packs were bad.
I tried troubleshooting the spark problems with a KAL Equip ignition analyzer
http://www.ebay.com/itm/Kal-Equip-Spark-...739&vxp=mtr
that clips on a wire and gives you
peak KV,
average KV and
spark burn time,
but found that with the 3.3/3.8 "wasted spark" two cylinder firing coil packs, you had to disconnect the wire to the other cylinder and connect it instead to a known good sparkplug simulator
http://www.ebay.com/itm/Adjustable-High-Energy-Ignition-Spark-Plug-Tester-Pick-Up-Coil-Diagnostic-Tool-/231314358857?epid=1326254621&hash=item35db690249:g:14MAAOSwxH1T-AoA
Re: 2009 Chrysler Minivan Code P0303 cylinder misfire [Re: Dartslantsix] #2334002
07/09/17 11:36 AM
07/09/17 11:36 AM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
When I had similar symptoms with my Mazda, it turned out to be bad injector seals. I replaced a bunch of unnecessary parts before I broke down and took it to the dealer. The codes it was throwing was for misfire on #5, and random misfire. I was thinking I had a spark issue, and ignored the distinct smell of gas under the hood...
Re: 2009 Chrysler Minivan Code P0303 cylinder misfire [Re: DaveRS23] #2335672
07/12/17 01:07 AM
07/12/17 01:07 AM
All the plugs looked to be the same condition when I pulled them. It is the code for cylinder 3.
The check engine light turned off again.
I haven't had time to dig into it yet, but I'll check the coil pack then check for vacuum leaks. If the intake gasket is leaking, it could cause a misfire, right?
I'll report back when I have more time to dig into it.
Thanks for the replies.
Re: 2009 Chrysler Minivan Code P0303 cylinder misfire [Re: Dartslantsix] #2335805
07/12/17 11:30 AM
07/12/17 11:30 AM
md
mopars4ever Online content
mopars4ever  Online Content
md
Had a misfire code on my PT that drove me crazy. Finally found out it was a burnt valve.
