indy hemi aluminum hemi
#1873375
07/19/15 10:11 AM
07/19/15 10:11 AM
Posts: 1,629 pa
572charger
pa
anybody run in to the block having no steam holes for my stageV HEMI heads
606 hemi pump gas best 9.60 at 142mph on motor 05 hemi daytona 1500 go-mango 4wd quadcab 2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
Re: indy hemi aluminum hemi
[Re: B G Racing]
#1874123
07/20/15 07:42 AM
07/20/15 07:42 AM
Posts: 1,629 pa
572charger
pa
thanks for the replys dt and bob
[Re: 572charger]
#1875984
07/22/15 06:56 PM
07/22/15 06:56 PM
Posts: 290 Cincinnati, Ohio
d7cook
Cincinnati, Ohio
Just for reference for those doing searches in the future KB blocks have a larger diameter flange at the top of the bore sleeve and the steam holes are relocated from the factory location. Stage V heads can be ordered with the steam holes in the KB location or on aluminum heads they can be plugged and moved. Cometic makes gaskets with the steam holes in the KB location.
1967 Coronet, 1989 Daytona tube chassis.
Former cars, 66 Charger, 67 R/T, 69 Coronet, 67 Dart GT.
-Banned for life from V8Buick.com-
[Re: d7cook]
#1876443
07/23/15 10:00 AM
07/23/15 10:00 AM
Posts: 13,380 Marion, South Carolina [><]
an8sec70cuda
Just for reference for those doing searches in the future KB blocks have a larger diameter flange at the top of the bore sleeve and the steam holes are relocated from the factory location. Stage V heads can be ordered with the steam holes in the KB location or on aluminum heads they can be plugged and moved. Cometic makes gaskets with the steam holes in the KB location. Back in 2006 when I bought my KB Hemi block, KB was the only place you could get those special Cometic gaskets w/ the steam holes relocated. I welded the holes shut in my MP heads and redrilled them using the gasket as a pattern.
[Re: dart games]
#1884940
08/04/15 01:33 PM
08/04/15 01:33 PM
Posts: 2,674 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
They are talking about the 2 holes circled here. Called "steam holes" by the exhaust port. These are in a slightly different location on a KB block.
2011 Drag Pak Challenger
