New to Duallies. Question. #2333543
07/08/17 12:01 PM
07/08/17 12:01 PM
Richmond, Indiana
19swinger70 Offline OP
Richmond, Indiana
I just picked up this '75 W300 Dump to use as a beater truck. Full time 4x4, 318 4spd. Runs great - motor rebuilt, new clutch, everything else gone through.
The axles have 4.88 gears in them - which is great for hauling - but a little steep at 65mph!. The tires are only 30 inch tall. Can I put a taller, and maybe more aggressive tread on a dually? The original split rims are gone - and have been replaced by newer steel wheels. I am just not familiar with the dually world - and what I can do with tires. I'd like to get the tires to 33" at the minimum- or maybe a little taller to help with rpms when I'm going 65mph. Also, would like a tread that will be better for driving through my pastures.
Any advice?
1970 340 swinger. sublime
1967 barracuda fastback BB
55 Plymouth Project
Re: New to Duallies. Question. [Re: 19swinger70] #2333586
07/08/17 01:04 PM
07/08/17 01:04 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
4.88's ?! That thing must barely crawl in granny first in low transfer case range! I'm sure you can go a little taller, with front too.
Re: New to Duallies. Question. [Re: 19swinger70] #2333669
07/08/17 04:07 PM
07/08/17 04:07 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Problem with going larger in diameter is that the tire usually gets fatter which could have the sidewalls rubbing each other. BTDT
If you don't need the pulling grunt, go to 3.54 gears.
Re: New to Duallies. Question. [Re: 19swinger70] #2333671
07/08/17 04:09 PM
07/08/17 04:09 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
4.88 and manual trans was the combo to help that poor 318 get out of it's own way. When I had a highway maint job back in high school they had some work trucks like that. I'd get to work early and get a head start to get to the job site.
only concern about the taller tire is that they often come with more aspect ratio. They do make spacer kits for that so the tires won't rub together.
Re: New to Duallies. Question. [Re: 19swinger70] #2333690
07/08/17 04:45 PM
07/08/17 04:45 PM
Wills Point, Texas
Hugh Jorgan Offline
Hugh Jorgan  Offline
Wills Point, Texas
if these would fit in the fenderwells....
https://tricities.craigslist.org/pts/6153717118.html
Re: New to Duallies. Question. [Re: 19swinger70] #2333736
07/08/17 06:42 PM
07/08/17 06:42 PM
Richmond, Indiana
Richmond, Indiana
Well, the gears do help the truck get up and move. The 318 has an RV cam in it - and it runs really well. The tires on it are actually new - so there is no need to replace them. I will probably just watch craigslist to see if there are any wheel and tire combos that i could snag and bolt on. Not a real urgent thing - I only use this truck for parts runs and working on our property. It will do 60-65mph, but the full time 4x4 running gear is screaming, as well as the 318.
55 Plymouth Project
Re: New to Duallies. Question. [Re: 19swinger70] #2333752
07/08/17 07:03 PM
07/08/17 07:03 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Cool truck. That thing would be a dog with 3.54's, 4.10's would probably be so-so. Yes you can do some research and run a taller tire with a narrow profile, remember you have to keep all 6 the same.
It's easy to convert that front Dana 60 to part time hubs, not sure if anyone still makes a part time kit for the NP203 transfer case.
My son is running 19.5 medium truck tires on his dually but it was big bucks buying new tires, rims etc.
Sheldon
Re: New to Duallies. Question. [Re: 19swinger70] #2333900
07/09/17 12:07 AM
07/09/17 12:07 AM
Cleveland Ohio
sportfury70 Offline
sportfury70  Offline
Cleveland Ohio
Love the truck! My dad had a 75 d300 when I was a kid. It had a 360 with low gears. Top speed was 70-half throttle or full throttle. Didn't matter.
Re: New to Duallies. Question. [Re: 19swinger70] #2333966
07/09/17 09:56 AM
07/09/17 09:56 AM
Maine
jerseybud Offline
jerseybud  Offline
Maine
I assume 16 inch rims? What size on there now?
235-85-16 is a 32 inch tire. To get taller than that means a wider tire. Not easy to balance the height with the width b/c of the dually axle
Re: New to Duallies. Question. [Re: 19swinger70] #2333982
07/09/17 10:54 AM
07/09/17 10:54 AM
STL ,MO
Handygun Offline
Handygun  Offline
STL ,MO
As mentioned the 4.88s are because of the 318. I ran 235/85/16's on my 88 D350 360/435/4.56 Dump for years and it was about the best combo for load, mileage,braking/accel/cruise I could get w/2-4 tons on it. I had a 75 D-600 I put 9.00/20's on it up from the 8.25's it came with trying to "gear it up" and it sapped all the power out of it. 318's get overwhelmed easily on heavy vehicles. Sounds like a set of lock out hubs would help.
Re: New to Duallies. Question. [Re: 19swinger70] #2333996
07/09/17 11:30 AM
07/09/17 11:30 AM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
Any advice?
If you want aggressive tread for driving thru pastures, leave the tire size alone and get aggressive tread. I think in the end you will like the truck better. My 2cents
Re: New to Duallies. Question. [Re: 19swinger70] #2334179
07/09/17 04:34 PM
07/09/17 04:34 PM
Cruising!
Q
QuickDodge Offline
QuickDodge  Offline
Q
Cruising!
I would leave the new tires on it and swap in a 5 speed overdrive transmission.
Re: New to Duallies. Question. [Re: jerseybud] #2344126
07/27/17 10:18 AM
07/27/17 10:18 AM
Scatchamatoon
Saskabusa Offline
Saskabusa  Offline
Scatchamatoon
I run this on my 93 dually.
Works well
Does the OP's truck have coined wheels?
There is a TSB out there in the internet showing how to mount dually wheels.
1974 Roadrunner
1967 Charger
Re: New to Duallies. Question. [Re: Saskabusa] #2344550
07/27/17 10:56 PM
07/27/17 10:56 PM
Richmond, Indiana
Richmond, Indiana
Works well
The rims are not split rims. I dont know what coined means?
55 Plymouth Project
Re: New to Duallies. Question. [Re: 19swinger70] #2345024
07/28/17 09:37 PM
07/28/17 09:37 PM
UP
finn Offline
finn  Offline
UP
Hub centric wheels would have flat faced lug nuts while stud centric wheels will have a tapered face lug nut and a tapered, ie coined seat to match the nut.
They aren't interchangeable.
