B1 PSO
#233338
02/22/09 10:45 PM
02/22/09 10:45 PM
Posts: 2,028 Trumbull,CT.
jim sciortino
Trumbull,CT.
Could a B1 PSO head, max N/A, with a 4.600 x 4.500, cast single 4, approach 1200hp, or would a sheetmetal with 2 carbs be a must???
I'm talking about a killer here, NOT a bracket build.
15+ comp, high buck ring stack, light bob, dry sump, .500+ lobe with 1.8s, Cubic or Book domi, Ti valves, CGI block, state-of-the-art port and manifold work, cam and dist. belt driven, all the good stuff.
Re: B1 PSO
[Re: AndyF]
#233342
02/22/09 11:13 PM
02/22/09 11:13 PM
jim sciortino
Trumbull,CT.
Call Best Machine and see what they say. I'm not sure there is a cast intake available that will make that power.
Not even if MBE or Wilson get their hands on it???
I think Chuck at Best makes about 1100 with a B-1 MC and a single 4.
Maybe he'll chime in.
Re: B1 PSO
[Re: Mike Swann]
#233344
02/22/09 11:31 PM
02/22/09 11:31 PM
jim sciortino
Trumbull,CT.
Hi Mike.
I thought the World CGI blocks are capable of a 4.600 bore.
That leaves 0.200 on adjacent wall thickness with a 4.800 Bore CL. Pretty thin.
0.300 with a 4.9 bore CL, but you would have to start out with a bare casting, relocate the seats, the ports wouldnt be in the right place in relationship to the seats to take advantage of the bore, etc.
.200 is thin, but I was under the impression that in a non power adder situation, .200 is acceptable.
I've heard in the Prostock blocks with CGI they go even thinner than that.
Maybe I'm nuts???
Re: B1 PSO
[Re: jim sciortino]
#233345
02/22/09 11:34 PM
02/22/09 11:34 PM
Posts: 1,093 Long Beach, CA
Mike Swann
Long Beach, CA
Hi Mike.
Maybe I'm nuts???
News to me, but what do I know? PS tends to throw a lot more money at their engines than we do. Wht kind of deck height?
8.30's @3400 lbs
Re: B1 PSO
[Re: 68CudaB1]
#233349
02/23/09 12:26 PM
02/23/09 12:26 PM
jim sciortino
Trumbull,CT.
I think the PSO could support 1200 @ 600" but NOT with only 15:1 and .900 lift, just my opinion....it would need to be a MAX EFFORT deal.
I believe our 596" B1MC will make over 1150 this year, well, I HOPE.....we made a little over 1130 last year and we made some changes, hopefully the right ones.
Thats why I put + signs on compression and cam numbers.
1150+ is some nice steam from a MC with a single.
Nice job...
Re: B1 PSO
[Re: jim sciortino]
#233350
02/23/09 12:39 PM
02/23/09 12:39 PM
Posts: 19,382 Las Vegas
Al_Alguire
Las Vegas
Well I would think you can get there with those cubes. My B1MC makes 1050 with 100 less cubes and a "conservative" cam.
Re: B1 PSO
[Re: jim sciortino]
#233351
02/23/09 01:30 PM
02/23/09 01:30 PM
Posts: 573 PA
68CudaB1
PA
Nice job...
Dont know about 1150 yet, who knows, maybe it will go down to 1100
Re: B1 PSO
[Re: 68CudaB1]
#233352
02/23/09 01:56 PM
02/23/09 01:56 PM
jim sciortino
Trumbull,CT.
Nice job...
Think positive.
