Re: Cam Degree Question for my 505
[Re: DonnieLawson]
#2336905
07/14/17 02:20 PM
07/14/17 02:20 PM
Posts: 14,515 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
When you move the cam, obviously the dot on the top gear isn't going to be straight down anymore..... You "moved" it.
Lifter on the left is an 821(standard series), lifter on the right should be a 2921(performance series).
[Re: DonnieLawson]
#2337337
07/15/17 01:39 PM
07/15/17 01:39 PM
fast68plymouth
So. Burlington, Vt.
Okay, let me rephrase it........
None of the cam companies manufacture flat tappets. They buy them.
The lifter on the left is made by Stanadyne, and is what Comp sold under part number 821-16 for years. They are a one piece "solid" lifter...... And they're heavy.
The lifter on the right is made by Hy-Lift Johnson, and used to be what you got when you bought 2921-16. They are a multi-piece design and are lighter than the Stanadyne part.
[Re: fast68plymouth]
#2337496
07/15/17 06:44 PM
07/15/17 06:44 PM
Posts: 229 Middletown , Ohio
DonnieLawson
Middletown , Ohio
Teachin an old dog new tricks.... I really appreciate everybody's help..... That's what makes these boards so awesome ! I painted the block today with Por15 engine paint...It looks good, I just hope it holds up. It looks glossier then the spray bomb stuff I've always used... Liquid Purity ![smile smile](/ubbthreads/images/graemlins/custom/smile.gif) The purist may not like it... but I do for my application. It's Hemi Orange I never thought I would brush paint an engine
#2337527
07/15/17 07:36 PM
07/15/17 07:36 PM
Posts: 43,342 Bend,OR USA
Cab_Burge
Any idea on who made the Federal Mogul hydraulic lifters ten + yrs. ago for both SB and BB Mopars ?
