Dana 60 help
#2333265
07/07/17 07:58 PM
07/07/17 07:58 PM
Posts: 339 Valley of the sun, AZ
2JcodeChargers
So I just got my 1970 Coronet done and on the road. 440 4 speed, great car. Rebuit 440, rebuilt 18 spline 4 speed, shifts like butter.. Heck why worry about the Dana, how can you hurt one of those??? So now I 've got a nicely done car with a Dana that howls like a bit%$# when you let off the throttle. Under acceleration/cruise it is is pretty quiet. Take your foot off the throttle and oh boy, can you hear it whine. It's the original rear (4:10) so I doubt the backlash suddenly went away, so I'm thinking it is one of the bearings. Questions is: If I buy a bearing kit how hard is it too replace the bearings? I know I can pull the axles and press new bearings on those. I think I could remove the carrier and replace the bearings on the sides of that (keeping the original shims all together, but seems to me to be almost impossible to replace the pinion bearings without the training or tools to adequately do that job. Am I wrong?? I hate the thought of taking the whole assy. out of the car, and taking it to a shop. any suggestions??
Re: Dana 60 help
[Re: 2JcodeChargers]
#2333304
07/07/17 09:36 PM
07/07/17 09:36 PM
Posts: 8,285 fredericksburg,va
cudaman1969
fredericksburg,va
Make sure the pinion nut is tight. If loose it sucks back into the case (when let off the gas) and changes pattern. I would replace all the bearings if you have to take apart. I also wouldn't chance the setup, redo it with the proper gauges-tools. Better in the long run.
Re: Dana 60 help
#2333689
07/08/17 04:44 PM
07/08/17 04:44 PM
Posts: 25,849 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Lots of shops will overhaul the rear in the car.
Re: Dana 60 help
[Re: TJP]
#2334193
07/09/17 04:52 PM
07/09/17 04:52 PM
John_Kunkel
Rio Linda, CA
Classic symptom of a loose pinion nut.
Also a classic symptom of a worn ring & pinion.
