Re: 68 satellite starts with relay but not key?
[Re: moparpaul66]
#2332804
07/06/17 11:10 PM
07/06/17 11:10 PM
Posts: 96,666 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
start circuit isn't complete to the key. check between the relay and key.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: amxautox]
#2332823
07/06/17 11:42 PM
07/06/17 11:42 PM
Posts: 4,693 Wichita
GY3
Wichita
Neutral safety wired up and functioning correctly?
[Re: stumpy]
#2332876
07/07/17 01:25 AM
07/07/17 01:25 AM
RapidRobert
What Stump said: there's an open inbetween the "ign 2" brown wire circuit starting from the ign sw out to the downstream end of the ballast. start with the bulkhead. pull the female terminal off of the "ign" terminal on the starter relay to disable the starter & have a helper hold the key to "start" & with the bulkhead halves seperated see of the rear (firewall) half specific "brown wire" terminal is hot with your meter. On a bare bones '68 it should be easy to pinpoint that brown wire terminal or www.mymopar.com will have a schematic of its location in the bulkhead. I'd say corroded bulkhead terminal(s) or a bad ign switch. if it is the pair of bulkhead terminals I have some NAPA part #'s. holler back with any news.
