Re: magnum head ???
[Re: dustpan man]
#233274
02/22/09 11:34 PM
02/22/09 11:34 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
The GM 3100 V6 springs are a perfect match for a cam that size and you will not get a cheaper deal from an aftermarket company like comp crane lunati... also NO machining nescacary.
Re: magnum head ???
[Re: dustpan man]
#233276
02/23/09 01:36 AM
02/23/09 01:36 AM
HotRodDave
Kalispell Mt.
Any impala or mini van with a 3.1 or 3.4 V6. Get the retainers and springs, less than $125 last time I got a set (they can't figure out why I always buy them in sets of 16).
Re: magnum head ???
[Re: HotRodDave]
#233277
02/23/09 09:42 AM
02/23/09 09:42 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
retainers are common with all LS series V-8's, too, and around here if you're junkyarding, pontiac grand ams and other N bodies are a good source if you want used....IIRC the changeover to these springs was ~ '94 or so. search the archives, I have the part numbers listed in my "cheap magnum spring" thread, and the cheapest place to order them new are gmpartsdirect.com
btw, is that 474" lift with 1.5 rockers, or the magnum's 1.6? if it's 1.5's (i.e. the MP 474 cam for LA's), it's actually .506" lift with the magnum rockers.
Re: magnum head ???
[Re: dustpan man]
#233279
02/23/09 04:22 PM
02/23/09 04:22 PM
patrick
Grand Haven, MI
I'd definitely go the GM 3100 spring route then....
Re: magnum head ???
[Re: dustpan man]
#233281
02/24/09 02:51 AM
02/24/09 02:51 AM
Posts: 576 Escondido, CA
kick_the_reverb
Escondido, CA
The Chevy springs are beehives.
"Hey mister, something's wrong with your car, it idles roughly" - number one comment I got in Israel when daily driving a 70 Barracuda with a lopey cam.
Currently working on - 1966 Dodge A100 van 318/auto Finally - disc brakes on the front. In the plans - rear disc brakes, B&M 250 blower
Re: magnum head ???
[Re: HotRodDave]
#233282
02/24/09 03:51 PM
02/24/09 03:51 PM
Posts: 47 Redding, CA
RDJ
Redding, CA
How much lift can the GM 3100 springs take? Can they go over .500" lift?
Re: magnum head ???
[Re: RDJ]
#233283
02/24/09 04:18 PM
02/24/09 04:18 PM
patrick
Grand Haven, MI
depends on what you can get for IH. check out the "best of discussion. in my specific measurements, they coil bind at 1.065", so to get adequate safety factor, I'd add want lift + 1.120" (.055" above coil bind) for my install height. on the uncut mag heads I have that I tried them on, IIRC I got just a touch under 1.6", so if you add a valve job that sinks the valves ~ .030", then .5" lift should be OK.
Re: magnum head ???
[Re: StandOnIt]
#233287
02/26/09 08:52 AM
02/26/09 08:52 AM
patrick
Grand Haven, MI
the stock springs in my old '96 ram would float the valves slightly before 5000 RPM....
Re: magnum head ???
[Re: patrick]
#233288
02/26/09 11:19 AM
02/26/09 11:19 AM
HotRodDave
Kalispell Mt.
Stock springs and .513 lift Mabey they "survive" because a flat tappet is so much lighter than a stock roller I would be scared to rev it up to 6000 though
Re: magnum head ???
[Re: HotRodDave]
#233289
02/26/09 12:29 PM
02/26/09 12:29 PM
Posts: 2,267 ILLINOIS
volaredon
ILLINOIS
Not to thread jack but on the subject of stock Magnum springs I'm about to put a set onto an LA 318; but use a stock 360 cam, (nearly identical to a Comp 252, minus~0.015" lift) the stock (non E 58) 360 has a lift of .410 (with stock LA shaft rocker gear) with Magnum rocker gear (1.6 RR) I come up with about a 0.438" lift on that same cam. This is going into a 3/4 T. pickup with a 727 and 3.55 gearz; I doubt the motor will ever see over 4K RPM; stock Magnum beehive springs good enuf??? My IH came out perfect to stock Magnum spec, (1.64")just a shade over 1-5/8" with reground stock Magnum-head valves, in a set of EQ 318-B's. I "only" have 5 cracked OEM Magnum heads here to cherry pick the best valves out of so I didnt buy new valves for that new set of heads. Gotta save money somewhere so I can have some left for the Project Car, right?
Re: magnum head ???
[Re: volaredon]
#233290
02/26/09 01:23 PM
02/26/09 01:23 PM
patrick
Grand Haven, MI
lift wise you should be fine. according to my dad's '97 ram FSM, the 318 mag cam is right around .450 lift.
