tablespoon of motor oil in my air cleaner assembly #2332499
07/06/17 01:56 PM
07/06/17 01:56 PM
Maryland
wally426ci Offline OP
Maryland
Pulled the air cleaner on my 2 barrel 318 68 D100 and there was a table spoon or so of newer looking motor oil in the base. Did I start it too soon after the previous change? indication of something else?
Thanks!
Re: tablespoon of motor oil in my air cleaner assembly [Re: wally426ci] #2332513
07/06/17 02:27 PM
07/06/17 02:27 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
Thanks!
Sounds like blowby to me? shruggy
Robert
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: tablespoon of motor oil in my air cleaner assembly [Re: wally426ci] #2332559
07/06/17 03:44 PM
07/06/17 03:44 PM
Maryland
Maryland
Hmm... just seemed wierd as it has never happened and it was newer looking oil (as in not dark in color...)
Thanks!
Re: tablespoon of motor oil in my air cleaner assembly [Re: wally426ci] #2332581
07/06/17 04:16 PM
07/06/17 04:16 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Clean it out, change the pcv valve and make sure the breather is clear and try it out again. If it's not using oil, it may not be a big concern.
Re: tablespoon of motor oil in my air cleaner assembly [Re: wally426ci] #2332643
07/06/17 05:33 PM
07/06/17 05:33 PM
Do you have a "friend" possibly messing with you on this work shruggy
Re: tablespoon of motor oil in my air cleaner assembly [Re: wally426ci] #2332743
07/06/17 08:55 PM
07/06/17 08:55 PM
Earth
Rob C Offline
Rob C  Offline
Earth
I like the new breather, PVC valve idea. The PVC valve may be mis functioning. Clogged, broken spring within, what ever. It could be causing an issue.
Re: tablespoon of motor oil in my air cleaner assembly [Re: Rob C] #2332890
07/07/17 01:54 AM
07/07/17 01:54 AM
As said: blowby/PCV
