Fuel tank and return line question
#2331892
07/05/17 01:43 PM
07/05/17 01:43 PM
Posts: 4,852 KENTUCKY
69CHARGERMD
KENTUCKY
70 Challenger,, Is there a way to "delete" the return line ?? I have a 3/8 line feeding the fuel pump from the tank,,,,and a smaller line running back to the tank...
This is a new tank,,,from Roseville for a car i am restoring,,, I am running a mechanical pump on the car.... I already have the feed and return line and tank plumbed front to back,,,,
Is there a way to not use the return line ? If not,,,what do i need to "plumb" the return line near the fuel pump ? Trying to "clean" things up under the hood,,,and didn't realize the duel line issue until recently as the car is nearing completion.. FYI,,this is not a stock appearing application thx, Doug
Re: Fuel tank and return line question
[Re: 69CHARGERMD]
#2331936
07/05/17 02:50 PM
07/05/17 02:50 PM
69CHARGERMD
KENTUCKY
Thanks Challenger,,,, I will need to figure out how this is "vented" as it runs near the fuel pump... I am researching some old threads you had replied to on a similar topic,,, I will post some more questions as i educate myself on the topic,,,lol,, thx for your help ! Doug
[Re: 69CHARGERMD]
#2331940
07/05/17 02:58 PM
07/05/17 02:58 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
The FSM, you do have one right, shows this.
[Re: 69CHARGERMD]
#2331970
07/05/17 03:51 PM
07/05/17 03:51 PM
Challenger 1
Cincinnati, Ohio
Thanks Challenger,,,, I will need to figure out how this is "vented" as it runs near the fuel pump... I am researching some old threads you had replied to on a similar topic,,, I will post some more questions as i educate myself on the topic,,,lol,, thx for your help ! Doug If it terminates near the fuel pump, then it is a return line. The vent line terminates near the firewall and is 2 pieces, the vent line. All you have to do is cap the return if you don't want to use it now. I sure would not remove it though, you might change your mind someday and could use A RETURN. I use returns on both of my cars and they have mechANICAL FUEL PUMPS.
[Re: 69CHARGERMD]
#2331983
07/05/17 04:10 PM
07/05/17 04:10 PM
69CHARGERMD
KENTUCKY
Thanks Challenger,,, As you mentioned,,it is a return line ( and not a vent line ) Do you see any problem running a 3 nipple fuel filter,,,( 3/8 for the feed and 1/4 for the return ? ) As an aside,,,I still need to "vent" my tank,,,,,,,,, I assume i can run a "vented cap" ? ( or do you have any other suggestions... ) I have already installed a flip top cap on the car,,, The filler tube has no port, etc for a "vent" ( long story short,,,but the car is a california ,,Western Sport Special car,,and had all the emission stuff on it,,,,i removed it when the tank was changed,,,,,so.....i do have a second "tube" in the trunk,,,next to the filler tube,,,that has about 4-5 small fittings coming out of it,,,,,right now,,,it's just mounted in the trunk for looks and has no further function to the gas tank like it did originally ) Curious on your thoughts,,,thanks for your help Doug ![wink wink](/ubbthreads/images/graemlins/custom/wink.gif)
[Re: 69CHARGERMD]
#2331994
07/05/17 04:42 PM
07/05/17 04:42 PM
Posts: 12,494 Western Colorado High Desert
moparmarks
On a 70 the vent line goes up into the trunk then back down and into the frame rail, unless your car is coded for N95 then it would have a 5/16" vent line going to a 3-nipple breathe cap on the motor.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: Challenger 1]
#2332013
07/05/17 05:12 PM
07/05/17 05:12 PM
Posts: 3,685 South San Francisco, Ca
70sixpkrt
Thanks Challenger,,,, I will need to figure out how this is "vented" as it runs near the fuel pump... I am researching some old threads you had replied to on a similar topic,,, I will post some more questions as i educate myself on the topic,,,lol,, thx for your help ! Doug If it terminates near the fuel pump, then it is a return line. The vent line terminates near the firewall and is 2 pieces, the vent line. All you have to do is cap the return if you don't want to use it now. I sure would not remove it though, you might change your mind someday and could use A RETURN. I use returns on both of my cars and they have mechANICAL FUEL PUMPS. Why do you want to use a 3 nipple fuel filter if your just going to cap the return line?
[Re: 69CHARGERMD]
#2332024
07/05/17 05:42 PM
07/05/17 05:42 PM
69CHARGERMD
KENTUCKY
Thanks everyone for the replies,,,,
I will just cap the return line if that would be ok,,, ( no reason to use the return line ??,,,benefits ? none ? )
Need help with how to vent the tank,,,, ( this is not the original tank,,and there are no extra ports on the tank to use....)
if the cap is vented,,,will that suffice ? Right now it just has the flip top gas cap,,,,,
[Re: Morty426]
#2332046
07/05/17 06:00 PM
07/05/17 06:00 PM
69CHARGERMD
KENTUCKY
Morty,,,,thanks for you reply. I knew it was going to get messy lol... I have a 3/8 fuel line ( 440 ) and the return line installed. ( no vapor line to deal with ) The sender i have in the tank has fitting for both the fuel feed line and return line,, ( can i cap that fitting on the sender for the return line ? ) I will need to figure out the cap or fill tube venting thx for the help Doug
[Re: 69CHARGERMD]
#2332069
07/05/17 06:25 PM
07/05/17 06:25 PM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
Morty,,,,thanks for you reply. I knew it was going to get messy lol... I have a 3/8 fuel line ( 440 ) and the return line installed. ( no vapor line to deal with ) The sender i have in the tank has fitting for both the fuel feed line and return line,, ( can i cap that fitting on the sender for the return line ? ) I will need to figure out the cap or fill tube venting thx for the help Doug Yes you can cap it at the sender as long no fuel is being sent there aka "fuel filter/separator" You just need to look at how it is going to vent. Let me go check my non-CA HEMI Challenger vs. my CA Challengers do I'll post some more info.
