Starter that won't disengage #2331831
07/05/17 12:00 PM
07/05/17 12:00 PM
Powell, Ohio ( Originally Pitt...
1970Dart3406 Offline OP
Long story short, my uncle has a 1979 Power Wagon Palomino Edition, 360, 4 Speed. He says that when he turns the key to start it that the starter will not disengage and continues to run. Said he had to disconnect the battery to stop it. He says it does the same thing if you try to start it by jumping the starter relay.
We are 6 hours apart, so I can't just check it out myself.
I say it's a starter problem.
Any ideas / advice that I can share with him?
Re: Starter that won't disengage [Re: 1970Dart3406] #2331835
07/05/17 12:01 PM
07/05/17 12:01 PM
md
mopars4ever Offline
mopars4ever  Offline
md
I agree
Re: Starter that won't disengage [Re: mopars4ever] #2331854
07/05/17 12:31 PM
07/05/17 12:31 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
rusty shaft, or broken spring, arm, or some such.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: Starter that won't disengage [Re: 1970Dart3406] #2331885
07/05/17 01:24 PM
07/05/17 01:24 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Bad solenoid.
Re: Starter that won't disengage [Re: 1970Dart3406] #2332072
07/05/17 06:28 PM
07/05/17 06:28 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
might also be loose and binding up
