Is this 79 2 barrel holley oem or replacement? #2331672
07/05/17 12:12 AM
07/05/17 12:12 AM
Tacoma, Washington USA
Adam71Charger Offline OP
Hi Im looking at a 79 dippy with 318. its been converted to electronic ignition/vacuum dizzy, but not sure about carb.
Ive never seen this carb before, is it a lean burn carb? One of the numbers stamped on it is R-8448, does that stand for Replacement?
Im replacing the intake and carb in the end, but I'd like to know more about it.
Re: Is this 79 2 barrel holley oem or replacement? [Re: Adam71Charger] #2331761
07/05/17 05:25 AM
07/05/17 05:25 AM
This was a lean burn car, so this is a lean burn carb?
Re: Is this 79 2 barrel holley oem or replacement? [Re: Adam71Charger] #2331798
07/05/17 10:33 AM
07/05/17 10:33 AM
md
mopars4ever Offline
mopars4ever  Offline
md
Looks correct for a 79 318. I would have to look up the numbers to be sure.
Re: Is this 79 2 barrel holley oem or replacement? [Re: Adam71Charger] #2331872
07/05/17 01:09 PM
07/05/17 01:09 PM
with the blue wire going into the innards I would say yes it is a LB.
