Re: A/F set up help [Re: 1fastaspen] #2331231
07/04/17 11:03 AM
07/04/17 11:03 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Maybe your idle circuit needs fattend up. once you get out about 2 turns you are limited by the restriction and bleeds. Wouldn't be the fist carb that was on a lopey cam that needed some idle circuit work.
Re: A/F set up help [Re: 1fastaspen] #2331283
07/04/17 12:31 PM
07/04/17 12:31 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
As pointed out any small air leaks will make it read lean. Slip on collectors are a big culprit for sure. Also as pointed out idle means little to overall performance. Also don't start shooting for an "ideal number" once you use it. ALL combos are diffierent and will usually require something other than that "optimal number" ALWAYS jet for performance then note the O2 readings. Don't get caught up in chasing a number and not pay attention to what the car is doing. One last tidbit Stoich is different for different fuels. FWIW we run the AEM stuff on the dragster and it works fine for us.
Re: A/F set up help [Re: 1fastaspen] #2331376
07/04/17 02:27 PM
07/04/17 02:27 PM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
Originally Posted By 1fastaspen
Okay I got an aem a/f set up and I can't get this this to read at an idol it just says it's lean and shows no numbers if I bring it up around 1500 rpm it's at 17-18 I got a good ground and a full 12 volt power supply anyone else have this problem and if so what was the cure and yes this was a brand new in the box unit
It should read something unless it's so lean it's out of range even for a wideband sensor, and that is possible. What carburetor and how much camshaft? What is the ignition timing at idle? For a street-driven car it is important to be able to read AFR at idle and just off-idle since that's where the carburetor is most of the time. Your carburetor might need some minor surgery to get it right.
twocents
Re: A/F set up help [Re: 1fastaspen] #2331414
07/04/17 03:17 PM
07/04/17 03:17 PM
plainwell,michigan
1fastaspen Offline OP
plainwell,michigan
It's a new thumper 1050 dominator cam is 630/650 after lash and if I remember it's in the 270/280 range I took it for a drive and it's 13.2 at wide open so it's a start
75 duster 440 in the works
71 pro street cuda
Re: A/F set up help [Re: 1fastaspen] #2331434
07/04/17 04:12 PM
07/04/17 04:12 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Good to hear .
I like dialing them in at the track. Watch the MPH and once you have the highest MPH that's what it likes.
Re: A/F set up help [Re: FastmOp] #2331437
07/04/17 04:22 PM
07/04/17 04:22 PM
plainwell,michigan
plainwell,michigan
Hope to get to the track this Friday and we can find out what it will do. This is a new to me car with the motor out of my Aspen made a few up grades ported eddy heads trick flow intake thumper dominator and the duster is 700 pounds lighter then the Aspen and that went the best of 10.88 @ 125 so we shall see what this does
71 pro street cuda
Re: A/F set up help [Re: 1fastaspen] #2332212
07/05/17 11:22 PM
07/05/17 11:22 PM
sioux falls, sd
10sec.dart Offline
10sec.dart  Offline
sioux falls, sd
Had the exact same problem, so have other guys at my local track, with open headers you will need some sort of back pressure, I slipped on some mufflers on the collectors and got a instant reading, just to set the idol, then took them off, other guys I have talked to did the same thing, just not enough air flow at idol, put a cheap set of mufflers on or something to make some back pressure and you will get a good reading
Re: A/F set up help [Re: 10sec.dart] #2333041
07/07/17 01:00 PM
07/07/17 01:00 PM
plainwell,michigan
plainwell,michigan
I run dyno max bullets on it and they dump at the rear tires
71 pro street cuda
Re: A/F set up help [Re: 1fastaspen] #2333102
07/07/17 02:58 PM
07/07/17 02:58 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Did you let the engine come up to temperature? I have an AEM and have used them for a few years now. When the gauge is cold it sometimes takes 30 seconds or so to get a reading. Also, on my 440 I don't have a choke, and I keep the throttle cracked a little and high idle it myself for a minute or so when I start the car. During this warm up time the gauge typically reads pretty lean, like high 15s, most likely due to incomplete combustion until the engine gets some heat in it. It probably takes until I've got about 130 degrees in the engine to get it to settle in.
