Plugs for e85 fuel injected boosted smallblock #2331051
07/03/17 10:43 PM
07/03/17 10:43 PM
Suffolk County, New York
1mean340 Offline OP
1mean340  Offline OP
Can anyone give me a good plug recommendation for a smallblovk 340 with w2 econo heads, e85 fed FITECH fuel injection and about 8PSI of boost to start? Did some research and came across a few different ones but there always seemed to be one thing off from what I wanted when searching through part numbers (non-resister type, not recessed, etc...). Thanks!
Re: Plugs for e85 fuel injected boosted smallblock [Re: 1mean340] #2332216
07/05/17 11:25 PM
07/05/17 11:25 PM
sioux falls, sd
10sec.dart Offline
10sec.dart  Offline
sioux falls, sd
ngk-8 race plugs, part number r5671a-8 stock # 4554
Re: Plugs for e85 fuel injected boosted smallblock [Re: 10sec.dart] #2332878
07/07/17 01:31 AM
07/07/17 01:31 AM
1mean340 Offline OP
1mean340  Offline OP
10.secdarr, I came across that plug a few times doing some web browsing but what concerned me is 1) it is a non resister plug and 2) it doesn't have a recessed tip. Think this will work with a fitech EFI system and boost? I don't have much experience with spec'ing out plugs for boosted EFI applications but I have always heard non resistor was a no no for EFI and it's better to use a recessed tip for boost.
Re: Plugs for e85 fuel injected boosted smallblock [Re: 1mean340] #2332881
07/07/17 01:38 AM
07/07/17 01:38 AM
1mean340 Offline OP
1mean340  Offline OP
And fwiw I'm running an MSD box with the FITECH and am using a new set of MSd 8.5 super conductor wires. They supposedly have good EMI suppression so hoping maybe that'll fix the issue of having a non resistor plug?
Re: Plugs for e85 fuel injected boosted smallblock [Re: 1mean340] #2332915
07/07/17 05:03 AM
07/07/17 05:03 AM
Cab_Burge Online work
Cab_Burge  Online Work
Does the Fitech system need resistor plugs and low resistance low EMF and RMI plug wires ?
If not one of them as a resistor components should work, correct?
Re: Plugs for e85 fuel injected boosted smallblock [Re: 1mean340] #2332929
07/07/17 07:19 AM
07/07/17 07:19 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
-8 is a little hot unless it's low boost. I would start with -9
Doug
