gear change!
#2330777
07/03/17 05:06 PM
07/03/17 05:06 PM
Posts: 4,732 Watertown, WI
MikeyT
Watertown, WI
Hi all,
I am looking to change the gears in 489 carrier from 3:91's to 3:55's besides the gears, what else do I need?
thanks! Mike
1969 Dodge Dart Swinger
Re: gear change!
[Re: MikeyT]
#2330849
07/03/17 06:42 PM
07/03/17 06:42 PM
RapidRobert
someone who knows what they are doing. crush sleeve eliminator. ring gear gasket. gear lube. a nice chunk of hundreds for the bill. Are you sure you want to go thru that for just a slightly taller gear? you might be able to find a set of 3:55's then sell or stash the 3:91's or a taller tire might be an option. at least I would do the math on paper for the RPM change.
Re: gear change!
[Re: MikeyT]
#2331098
07/04/17 12:09 AM
07/04/17 12:09 AM
Posts: 20,176 Park Forest, IL
slantzilla
Park Forest, IL
Changing gears isn't that hard if you spend a few dollars on tools. Ratech makes a really nice tool for setting pinion depth that is around $25. They also have solid spacers to eliminate the crush sleeve. Dr. Diff has some nice installation kits too.
I too vote for leaving the 3.91 together. There's enough open center sections floating around to get one cheap and put your new gears/SG unit in.
Re: gear change!
[Re: 383man]
#2332136
07/05/17 08:42 PM
07/05/17 08:42 PM
Posts: 12,072 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
They usually sell a gear instalation kit which should come with all you need like pinion and carrier bearings and the oil seal and so on. Ron The install kit is definitely the way to go. You'll just need to know if you have the large carrier bearings or the small ones. Lots of videos on-line on how to do the swap. Best to have an experienced tech do the job, but you can pull it off if you just take your time.
Master, again and still
Re: gear change!
[Re: MikeyT]
#2332143
07/05/17 09:09 PM
07/05/17 09:09 PM
slantzilla
Park Forest, IL
Yes, it is not really hard if you have the right tools, but it is tedious.
I sand the ID of the pinion bearings so they slip on and off. Makes setting the shim pack a ton easier.
