Trying to start 69 d100 what is the minimum I need to start it #2330733
07/03/17 03:54 PM
07/03/17 03:54 PM
spokane/pullman Wa
ryanf Offline OP
ryanf  Offline OP
spokane/pullman Wa
Hello, I have a 69 d100 that I am trying to get started. Been sitting for years, the prior owner started a new wing harness and never finished. I'm trying to get the engine running and complete it from there but I do not trust the wiring.
I've got the starter working and now trying to get spark which I can't seem to get. It has a stock coil and msd 6a box. Any way to test these as I couldn't find anything? Also is there something I can pick up cheap and get this running instead of keeping the msd?
Ryan
Re: Trying to start 69 d100 what is the minimum I need to start it [Re: ryanf] #2330739
07/03/17 04:02 PM
07/03/17 04:02 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Points distrubutor is pretty simple to make a spark with. Dist wire to neg side of coil. 12volts to + side of the coil, distributor grounded to block, should be sparking. The hold down clamp will ground it to the block.
Hard to make it any easier than that. Forget the msd right now, get it running so it starts right up, then get fancy later.
Re: Trying to start 69 d100 what is the minimum I need to start it [Re: ryanf] #2330744
07/03/17 04:14 PM
07/03/17 04:14 PM
spokane/pullman Wa
ryanf Offline OP
ryanf  Offline OP
spokane/pullman Wa
Ok thanks, and I take it my best bet is to go junkyarding and try to find a points for a 318?
Re: Trying to start 69 d100 what is the minimum I need to start it [Re: ryanf] #2330745
07/03/17 04:15 PM
07/03/17 04:15 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Well all small block Mopar distributors are the same dimensions. 273 318 360. What distributor do you have now?
Re: Trying to start 69 d100 what is the minimum I need to start it [Re: ryanf] #2330746
07/03/17 04:18 PM
07/03/17 04:18 PM
spokane/pullman Wa
ryanf Offline OP
ryanf  Offline OP
spokane/pullman Wa
It is the stock 318 distributor going to a msd 6a box and stock coil.
Re: Trying to start 69 d100 what is the minimum I need to start it [Re: ryanf] #2330795
07/03/17 06:01 PM
07/03/17 06:01 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
A stock points distributor? Why not use that one?
Re: Trying to start 69 d100 what is the minimum I need to start it [Re: ryanf] #2330806
07/03/17 06:18 PM
07/03/17 06:18 PM
spokane/pullman Wa
ryanf Offline OP
ryanf  Offline OP
spokane/pullman Wa
The distributor is for an electronic ignition
Re: Trying to start 69 d100 what is the minimum I need to start it [Re: ryanf] #2330818
07/03/17 06:35 PM
07/03/17 06:35 PM
with what you have, confirm that it is wired right, if with the MSD/OE coil you tie the ign1 blue wire (run) circuit to the ign2 brown wire (crank) circuit then T from them to the coil positive primary & do/check the rest of the MSD basic wiring. both the MSD & the coil need to be hot in cranking and in run.
Re: Trying to start 69 d100 what is the minimum I need to start it [Re: ryanf] #2330839
07/03/17 06:40 PM
07/03/17 06:40 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Try turning the key in the run position and jump the starter relay to crank the engine. Some times you won't get spark in the start circuit but will in the run. Be sure it's out of gear and the brake is on just in case it fires off.
Re: Trying to start 69 d100 what is the minimum I need to start it [Re: stumpy] #2331260
07/04/17 11:50 AM
07/04/17 11:50 AM
moparx Offline
moparx  Offline
the start circuit needs 12volts to the coil to get the car to start. then, the run circuit switches to around 9volts to the coil running through the ballast resistor. providing the wiring is correct.
beer
Re: Trying to start 69 d100 what is the minimum I need to start it [Re: ryanf] #2331319
07/04/17 12:48 PM
07/04/17 12:48 PM
ohio
bbtrux Offline
bbtrux  Offline
ohio
If its a manual trans, you may wanna confirm the clutch disc isnt stuck to the flywheel/ pressure plate.
Re: Trying to start 69 d100 what is the minimum I need to start it [Re: ryanf] #2331980
07/05/17 04:04 PM
07/05/17 04:04 PM
Des Moines IA
Soopernaut Offline
Soopernaut  Offline
Des Moines IA
It is not stock for that truck. Is it a later engine?
1970 Dodge d100/eventually going on a 77 D100 frame
