DRAG RADIALS #2330489
07/03/17 01:51 AM
07/03/17 01:51 AM
kalamazoo, MI.
VIPERDUST Offline OP
kalamazoo, MI.
Looking to put some new tires on the car. Looking for real results, and which brand of drag radials. Looking for 28" 10.5 x 15. going on 10" rims. Currently running Hoosier bias ply, 28" 11" x 15" , which are about worn out. Car is 70 Duster, caltracs, mono leafs, 340, 904, 4:30 spool, 8-3/4, 3070 lbs., with me. average 60 ft. has been 1.51 to 1.54. 11.20's at 118mph. Thanks for any replies, Matt
Re: DRAG RADIALS [Re: VIPERDUST] #2330490
07/03/17 01:55 AM
07/03/17 01:55 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I can tell you what to NOT get,,,,Nitto
Re: DRAG RADIALS [Re: CSK] #2330493
07/03/17 02:07 AM
07/03/17 02:07 AM
kalamazoo, MI.
kalamazoo, MI.
check, no nittos
Re: DRAG RADIALS [Re: VIPERDUST] #2330500
07/03/17 02:24 AM
07/03/17 02:24 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
M/T has been berry, berry good to me. Haven't tried the radials YET?
Re: DRAG RADIALS [Re: VIPERDUST] #2330534
07/03/17 05:33 AM
07/03/17 05:33 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
MT Pro Bracket Radials , 28x10.5R15
Just got my second set , 18 months racing well over 110 passes last set . Very happy with results .
Good shocks and different set up needed when swapping from rag slicks .
Also don't forget they do not grow .
I have also run ET street radials(275/60) , 275 Pro's and Hoosier 275 radials . Pro bracket hands down better . Especially life span . Very consistent .
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: DRAG RADIALS [Re: VIPERDUST] #2330540
07/03/17 07:51 AM
07/03/17 07:51 AM
Mo.
racerx Offline
racerx  Offline
Mo.
Curios on why this tires are faster work is it because of the no growth in the tire or sound sort of special compound?
Re: DRAG RADIALS [Re: racerx] #2330546
07/03/17 09:08 AM
07/03/17 09:08 AM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
I just made the switch two weeks ago from a Hoosier Quick Time Pro to a Hoosier Drag radial 295/95 -15 on the recommendation of several friends. So far I only have about 12 runs on them but I like them as i can run more air pressure and they don`t need a big burnout. My 60 ft got a little lower maybe 1 or 2 hundreds but I also did a gear change from 4.10s to 4.30s. These runs have been in the heat as its been pretty hot the last few race days I am looking forward to see how they work in the cool, fall air, my 60fts have been consistent so far.
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: DRAG RADIALS [Re: VIPERDUST] #2330566
07/03/17 10:38 AM
07/03/17 10:38 AM
Alberta
Wookie316 Offline
Wookie316  Offline
Alberta
I run the 30x10.5 Hoosier radial slick. In my tank I've 60 foot 1.37 at 4100 lbs with 20 PSI in them. I'll never go back to bias. At the top of the track they are nice and stable too. Here is a slow motion video launch. 71 Charger launch
1971 Plum Crazy Super Bee. 572 World Aluminum block with a Cope 727 & Dana 4.10 out back. 9.88 @ 138 with a 1.35 60 NA. Dialed back to 10.0’s. 4000 lbs with me in it.
Re: DRAG RADIALS [Re: VIPERDUST] #2330574
07/03/17 10:58 AM
07/03/17 10:58 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
While I have not personally run them, I have heard very good things about the M/T Pro Bracket Radials.
My son has some and really likes them.
ECU shows dead hook 99% of the time, sequential EFI 408, high 10s.
Bill
Re: DRAG RADIALS [Re: VIPERDUST] #2330577
07/03/17 11:06 AM
07/03/17 11:06 AM
an8sec70cuda Offline
Never run them myself, but I agree w/ the others...the M/T Pro Bracket Radial is what I'd run if I had the choice.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: DRAG RADIALS [Re: VIPERDUST] #2330630
07/03/17 12:35 PM
07/03/17 12:35 PM
kalamazoo, MI.
kalamazoo, MI.
That's what I was looking for, some real world feedback, I think I am leaning towards the Mickeys.
Re: DRAG RADIALS [Re: VIPERDUST] #2330642
07/03/17 12:57 PM
07/03/17 12:57 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I tried radials once, spun the things to half track....I will stay with slicks.
Re: DRAG RADIALS [Re: VIPERDUST] #2330680
07/03/17 01:52 PM
07/03/17 01:52 PM
Can , Nova Scotia , Cape Breto...
caper Offline
caper  Offline
I have ran the 295/65 x 15 for over 8 years. car weigh 3600 lbs with me in it. 19 lbs. best 60' 1.40, Very good on a prep track, not worth a fluff on a poorly prepped track. I would check to see if other people are running radials on the track you race on and go from there.
New best 10.18 , 1.40 60 ft 496 Scott Brown built, street driven 3600 lbs,654 hp , 653 ft tq
Re: DRAG RADIALS [Re: VIPERDUST] #2330689
07/03/17 02:08 PM
07/03/17 02:08 PM
Minnesota, USA
humpty Offline
humpty  Offline
Minnesota, USA
I've run both MT and Hoosiers. I prefer the Hoosiers as they are lighter and don't release nearly the amount of rubber as the MT's, which make for easier cleanup. The MT's last longer and the Hoosier's are or at least were banned from some classes. If you can get the Drag Radials to hook they can improve ET's. They are very unforgiving however. They don't recover nearly as good as a Bias Ply tire. They need to be dead hooked, and kept planted. Any significant offloading results in spinning. I'm still upgrading my suspension to get them to work. Hoping to make some passes this weekend!
Re: DRAG RADIALS [Re: humpty] #2330709
07/03/17 02:53 PM
07/03/17 02:53 PM
ca
sergio Offline
sergio  Offline
ca
My car is very close to yours in set up and ets.I run the 10.5 x28 mt pro bracket radials at 18psi,hooks anywhere.More consistent than the bias slicks,much smoother down track ,slightly more mph and better reaction times.I have the Calvert Adj. rear shocks,with bias slicks worked best at full stiff, the radials like a litter softer(2 clicks less). Also they don't require much of a burnout.
Re: DRAG RADIALS [Re: VIPERDUST] #2330924
07/03/17 07:13 PM
07/03/17 07:13 PM
N.W. Indiana
DblOJoe Offline
DblOJoe  Offline
N.W. Indiana
Matt, I've got a set of Hoosier 30x10.5's that still have some life left if you want to try them out.
Re: DRAG RADIALS [Re: VIPERDUST] #2330941
07/03/17 07:33 PM
07/03/17 07:33 PM
Parts unknown
590 Challenger Offline
Parts unknown
315 M/T Pros, 1.16 60' with caltrac and mono, much more left in the combo
Re: DRAG RADIALS [Re: VIPERDUST] #2330992
07/03/17 08:27 PM
07/03/17 08:27 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I like the Pro Bracket radial in a 28x10.5 as well.
68 Barracuda Formula S 340
Re: DRAG RADIALS [Re: VIPERDUST] #2331056
07/03/17 10:53 PM
07/03/17 10:53 PM
Liverpool, NY
SILVER67 Offline
SILVER67  Offline
Liverpool, NY
G/f is running the Mickey 3754x drag radial.
Repeats within .01 or .02
That measures 28x10
10" rim
Almost dont need a burnout
I use the PBR 9x28
That has been repeating within .01 lately
7" rim
Minimal burnout
Both @ 16.5
Re: DRAG RADIALS [Re: VIPERDUST] #2331121
07/04/17 01:01 AM
07/04/17 01:01 AM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
I have run both my and Hoosier. For your car best tire is the Hoosier 295 the new one I think it's ds2. It is Hoosiers version of the mt pro. An 11 sec or even 10 sec car should not need "radial prep" track to use these tires. My buddy's nova has the new Hoosier 295's on it and it runs 9.50's all the time. Get the Hoosiers they are way better on non prepped tracks.
....BAD A$$ STREET CAR.....
