How and where do I set 4 link??? #233044
02/22/09 07:28 PM
02/22/09 07:28 PM
Woodstock , Georgia
Mopar_racer_99 Offline OP
Woodstock , Georgia
OK guys, as you know I just finished new sw 4 link back half, now where do I set the bars and shocks, and no I have not scaled the car have to work a little more OT for afford the 700 for the scales. Here is the ic list from a program. car is 115.5 wheel base motor is 9 inches to the crank cl. Shocks are single adjustable qa1. John
8.72 @ 154.6 ,68 Charger 578ci 440-1s, 3000# w/drvr, 2150 den/alt NA
Re: How and where do I set 4 link??? [Re: Mopar_racer_99] #233045
02/22/09 07:54 PM
02/22/09 07:54 PM
MR_P_BODY Offline
MR_P_BODY  Offline
SB or BB, would help if you knew the CG of the car
or at least the % of the rear and total weight.
But as a start point I'd go with the 42.3" IC length
and it was something like 3.8" up, shocks set about
3/4 of the way to full tight ... this is just a guess
without knowing the other facts
Re: How and where do I set 4 link??? [Re: MR_P_BODY] #233046
02/22/09 08:19 PM
02/22/09 08:19 PM
Woodstock , Georgia
Woodstock , Georgia
578 ci big block 914 hp 850 tq old weight w/ladder bar was 2880 52% front 48 rear, weighing everything in and out looks like weight should be same.
Re: How and where do I set 4 link??? [Re: Mopar_racer_99] #233047
02/22/09 08:25 PM
02/22/09 08:25 PM
MR_P_BODY Offline
MR_P_BODY  Offline
In that case I'd use a base line of 56 long and 3 up
Re: How and where do I set 4 link??? [Re: MR_P_BODY] #233048
02/22/09 08:31 PM
02/22/09 08:31 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
That sounds very close, I was thinking 52 and 4
Re: How and where do I set 4 link??? [Re: dthemi] #233049
02/22/09 08:41 PM
02/22/09 08:41 PM
Woodstock , Georgia
Woodstock , Georgia
I can get 55.5 and 3 but I can only get 52 and 8 not 52 and 4. John
Re: How and where do I set 4 link??? [Re: Mopar_racer_99] #233050
02/22/09 08:53 PM
02/22/09 08:53 PM
Q
Quicktree Offline
Quicktree  Offline
Q
I would have some wheelie bars on it first time out. you don't want to put it on the bumper. I would go with the longer of the 2.
Re: How and where do I set 4 link??? [Re: Quicktree] #233051
02/22/09 09:09 PM
02/22/09 09:09 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I'd start with the longer set up... it
might be a little conservative but that me
Re: How and where do I set 4 link??? [Re: Mopar_racer_99] #233052
02/24/09 08:41 PM
02/24/09 08:41 PM
usa,pa
jkwedge540 Offline
jkwedge540  Offline
usa,pa
Ok guys, same car,4 link,3500#,925 hp,765tq, 10.5 tire, lots of spray. Were do i start.
Re: How and where do I set 4 link??? [Re: jkwedge540] #233053
02/24/09 08:54 PM
02/24/09 08:54 PM
Woodstock , Georgia
Woodstock , Georgia
When moving the bars do you move one bar at a time. adjust hiems so bolt slips in tighten jam nuts and then move to next bar, or move bar and force housing into postion so bolt goes in? I know this sounds stupid but remember I have never worked on a 4 link suspension and my bickle book doesnt say. JOhn
Re: How and where do I set 4 link??? [Re: Mopar_racer_99] #233054
02/24/09 09:22 PM
02/24/09 09:22 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Once you get the rear end into position then each bar
has a purpose... the 2 lower bars set your length
the top left sets the pinion angle, then the top
right is for setting pre-load. When you want to
change IC lengths and heights the first thing is
to get the pre load bar back to 0(bolt slips in and
out)... you always have 3 bars in place unless you
want to have the rear roll on you, one at a time
you
move each bar to the new hole, lengthening or shortening
the heim as needed.... once all the bars are in the
new holes measure the rear for being square(I use
my front 4 link cross bar), next is to check the
pinion angle... once these are set then tighten
down the bolts and lock nuts.... leaving the pre load
for the last thing... then set it back to what it
was before(1/2 turn or what ever). When we talk
pre load we USUALLY talk flats, thats the flat of
the hex on the bar. IF the car launches but goes
slightly right... you need to add pre load this
means SHORTEN the top right bar... we might say
give it 1 more flat.... if the car goes left you
have too much pre load OR you might need to go
negative pre load.... this is when you lengthen
the top bar...... there ya go now you are just like
the rest of us 4 link guys... time to test
Re: How and where do I set 4 link??? [Re: MR_P_BODY] #233055
02/24/09 09:45 PM
02/24/09 09:45 PM
Chowchilla,ca
Chassisman Offline
Chassisman  Offline
Chowchilla,ca
...and remember...out of all those IC points on that sheet of paper...only about 4 of those will work.....now go find em !!!!
Re: How and where do I set 4 link??? [Re: Chassisman] #233056
02/24/09 09:55 PM
02/24/09 09:55 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Ron, maybe you can give JKwedge some suggestion for
his set up. But wedge will you be hitting any spray
off the line and will you be using a progressive timer
for the spray. Also what do you figure the bias is
for the weight and do you know the CG of the car
Re: How and where do I set 4 link??? [Re: MR_P_BODY] #233057
02/24/09 10:18 PM
02/24/09 10:18 PM
Chowchilla,ca
Chassisman Offline
Chassisman  Offline
Chowchilla,ca
Mike....your doing just fine...I only pop in and out anymore.Besides I got pretty roughed up by a fellow member because I didnt answer his email in a timely manner.So I'm not feeling sooooo generous anymore.Especially since I was gone for over a week on my only vacation for the year when he sent me the Email.
Re: How and where do I set 4 link??? [Re: MR_P_BODY] #233058
02/25/09 02:09 AM
02/25/09 02:09 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Well to start and I am no expert here but long and low is a good place to be. So I would go with the 55 or more out numbers. Mine is WAY out and down, but it is a different style car. In the end each car will need something different. Only way to know is to try different spots. With trial and error you will find the "sweet spot". Good luck with it.
Re: How and where do I set 4 link??? [Re: Al_Alguire] #233059
02/27/09 09:07 PM
02/27/09 09:07 PM
usa,pa
jkwedge540 Offline
jkwedge540  Offline
usa,pa
Ok, I found my notes. First, car is 53.2% front 46.8% rear.Balance point is 62inc. Car is 3500# 540 big block. lot of spray. spraing off the line.I have tried a few ic points.need some info.
