AGM or Lithium???
#2329779
07/01/17 03:49 PM
07/01/17 03:49 PM
Posts: 984 San Diego CA
65 Hemi
San Diego CA
What has been your experience with these batteries? Getting ready to upgrade system.
Doug
MOPAR or NO CAR!!! 1965 Dodge Coronet soon a 6.1 Hemi with a Magnson blower 810 hp on pump gas 1964 Dodge Polara 582" Indy alum Block 426-1RA heads, 1933 Plymouth PE all Steel, LT1 4L60E 1959 Plymouth Savoy 33,000 mile survivor Old cars are never done. They are ongoing projects!
Re: AGM or Lithium???
[Re: 65 Hemi]
#2329797
07/01/17 04:33 PM
07/01/17 04:33 PM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
I don't know much about the lithium stuff. I do know that the lithium stuff is expensive and not everyone seems to have a hold on how they should be cared for and charged. It wasn't to long ago that Boeing had to ground planes due to problems with lithium batteries. When huge companies Boeing and Samsung have problems with something as simple as a battery it makes you wonder how good the tech is on the ones we can buy for our race cars? I don't think I am ready to have one in my car that is parked in my garage yet lol.
I recently met a guy that worked for Bell Helicopter as a go between for the FAA and Bell. He was trying to get lithium batteries approved for a new helicopter they were working on. The problem he was having with the FAA was that they wanted to them to build a steel cage around the batteries, that cage weighed about 85lbs and washed the savings from the lithium batteries. Stuff like that makes me question them.
68 Barracuda Formula S 340
[Re: 65 Hemi]
#2330082
07/02/17 08:29 AM
07/02/17 08:29 AM
crabman173
crabman173
AGM is the way to go I use one on my dragster starting a 14:1 engine with no charging system--it is 2 1/2 years old and doing great--No expensive charger needed just one from NAPA with an AGM setting ( important but not hard to find)
[Re: 65 Hemi]
#2330146
07/02/17 12:12 PM
07/02/17 12:12 PM
Posts: 19,372 Las Vegas
Al_Alguire
Las Vegas
I have Lithium in one car and a lieghtweight AGM In the other. I can tell you the cranking ability of the Lithium battery is FAR FAR superior to the AGM unit, in fact than two AGM units. It was a big factor in my switching to the Lithium along with the weight. One eight pound battery vs a total weight of 84lbs of AGM battery.
There does seem to be some lithium batteries that are better than others for sure. One thing for sure is IF you go Lithium get that companies charger and follow their directions to a T.
[Re: 65 Hemi]
#2330158
07/02/17 12:42 PM
07/02/17 12:42 PM
65 Hemi
San Diego CA
Thank you for all the info. I currently have 2 red tops (80+ lbs) but they are 2008 batteries. I want to run some street classes but they make you run a 35 mile trek through town and I'm concerned. I do run a alternator. I am going to call Go Lithium tomorrow and XS power and see what they say.
Doug
[Re: 65 Hemi]
#2330167
07/02/17 01:06 PM
07/02/17 01:06 PM
Al_Alguire
Las Vegas
You can run a lithium with an alternator, the issue will be they seem to all have a MAX voltage for charging. That would be the concern, it is also what gets some people into trouble trying to use their existing 16 volt charger on their lithium battery. Most lithiums I have seen have a max voltage of 17.8-17.9. MOst 16 volt AGM chargers will go to 18.5-7, this will certainly cause an issue with a lithium.
[Re: 65 Hemi]
#2330196
07/02/17 02:40 PM
07/02/17 02:40 PM
crabman173
crabman173
My XS has been a great buy--It has served me very well --I use a $70 charger from NAPA It has never let me down--I will buy another when the time comes
[Re: ]
#2330462
07/03/17 12:44 AM
07/03/17 12:44 AM
Posts: 90 North Carolina
CALSDART
North Carolina
What is the name or part number of the NAPA Charger
Calvin Thompson
[Re: CALSDART]
#2330572
07/03/17 10:53 AM
07/03/17 10:53 AM
crabman173
crabman173
What is the name or part number of the NAPA Charger It just has a switch that says normal/agm/gel I have used the agm setting and battery performs well for near two years now I was in fear of not using the high $$$$ charger but after talking to techs at many battery places decided that I was OK and apparently so NAPA one died so went with Schumacher unit from Wally world with same switch and price range--have used it over a year now same deal
[Re: 65 Hemi]
#2330734
07/03/17 03:54 PM
07/03/17 03:54 PM
65 Hemi
San Diego CA
Thanks for all the input. I believe the AGM technology is best suited for my situation. Starting and stopping in driving the car around town I think the AGM battery will be better. XS power 16 volt battery with there 15 amp charger. I was thinking of just mounting the charger in the car. It only a few lbs. I ordered a 16 volt alternator 140 amps that should help.
Doug
[Re: 65 Hemi]
#2331293
07/04/17 12:35 PM
07/04/17 12:35 PM
Al_Alguire
Las Vegas
The Cuda had the charger mounted in the truck for years and never an issue..
