440 Engine Build Questions
#232956
02/22/09 05:36 PM
02/22/09 05:36 PM
Posts: 2,335 Addison Twp, Mi.
RobG
Addison Twp, Mi.
I have been noticing a large number of 440 motors for sales on a number of sites. I see a bunch of 440 motors from campers (1972 to 1977 model year vehicles) listed for between $500 and $750. Do these motors make good foundations if you want to build a motor with good zip for the street and occasional strip use?
I was thinking of replacing my 340 small block in my Cuda with a 440. I was going to use the engine build time as a good father son project.
I am not rich...but I get off my ass everyday to make sure I am not broke!
Can we get the Mexican cartels to help us with our supply chain issues? They don't seem to have any trouble getting stuff from one place to another.
Re: 440 Engine Build Questions
[Re: MagnumGT]
#232959
02/22/09 07:25 PM
02/22/09 07:25 PM
Posts: 20,972 A collage of whims
topside
A collage of whims
I think you'd get better bang for the buck and have an easier project by going through the 340. Depending on how far you want to go, a 340 can get you into the 10s or make a great street motor, especially with a stroker kit. The '70s 440s have very low compression, requiring a set of pistons & a rebuild at the least, are heavier, and you'll have to make a lot of changes to the car to accomodate it: trans, cooling, mounts, accessory drives, etc.
[Re: topside]
#232960
02/22/09 10:20 PM
02/22/09 10:20 PM
DaytonaTurbo
Manitoba, Canada
The 70's 440's are good motors and a good basis for a nice street or street/strip build. Try and get a 440/727 out of a passenger car, less headaches that way. Lots of the campers/motorhomes came with the industrial 440, which to use in a car you would have to junk the whole top end of the motor(heads, intake, exhaust, water pump housing, oil pan, etc) as well the industrial applications usually came with the short tail shaft 727 which I've never heard of anyone using in a car but I don't know the specifics on them to know if it'd be usable with a custom length driveshaft or not.
Were your plans to buy a 440, clean it up, regasket it, maybe do a hone'n're-ring in your garage and drop it in or did you want something as a basis for a full motor rebuild?
[Re: DaytonaTurbo]
#232961
02/23/09 11:12 AM
02/23/09 11:12 AM
RobG
Addison Twp, Mi.
I was thinking more along the line of a re-build with a good amount of new parts. I am researching the cost involved with the build. I have always neen a small block guy and venturing nto the world of big blocks is new to me. building a stroked small block may not be a bad idea too.
[Re: RobG]
#232962
02/23/09 11:15 AM
02/23/09 11:15 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
be careful once you go big block you'll never go back. $ for $ a 440 will stomp a mud hole in ANY small block. ![](/ubbthreads/images/graemlins/stirthepot.gif)
[Re: RobG]
#232963
02/23/09 12:04 PM
02/23/09 12:04 PM
DaytonaTurbo
Manitoba, Canada
If you want to build a stock crankshaft engine, a 440 is still a good bet. If you want to spend the $ on a stroker kit, then either a 440 or a 400 would be what you want. Depends on how fast you want to go. If 500hp is what you want, a stock 3.75 stroke 440 will get you there with a pretty straightforward type build.
If you're worried about engine block quality, don't. Poor quality blocks in the 70's was a chevy thing, the late 440 blocks were as good as or better than the earlier ones.
[Re: DaytonaTurbo]
#232964
02/23/09 12:32 PM
02/23/09 12:32 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
Dollar for dollar, the money to rebuild is very similar. A little more for the RB, but it's all the same operations, so it's the parts costs that get you. As far as a 440 being "all that"... It is much less expensive to equip a 273-360 car with a 4" crank, then put a big block in one. And that 4" crank makes any so equipped car lots mor fun to drive than ANY 440. (and yes, I've built and had both, including big strokers. So the big and small block lines are now blurred. For total lowest budget, I'd rebuild the 340 into a 418. Otherwise you need brackets, linkages, driveshaft, exh manifolds/headers, transmission, and radiator or WP housing... al above and beyond the rebuild costs. The big block when popping the hood is a real show stopper tho. The 4" engines look boring...lol.
[Re: moper]
#232965
02/23/09 01:57 PM
02/23/09 01:57 PM
RobG
Addison Twp, Mi.
I see 360 blocks are easily available - have you ever stroked a 360? What power output can you get with one?
If I can get a '74 440 out of a B-van motor home with the 727 tans for $600 - is it a good starting point for a 500 hp setup? What do you think my total cost into this project may run ($3500 for machining and parts)?
[Re: Mr.Yuck]
#232968
02/23/09 03:27 PM
02/23/09 03:27 PM
Posts: 75,126 A Banana Republic near you.
JohnRR
I know their can be differences in industrial blocks and "normal" blocks. Some of the motor home blocks will work but things like oil pan, H2O pump might be different. If you are starting from scratch you might just want to pick up a 400 block and stroke it. With the price of kits these days it makes no sense to re-do a 30+ year old block and machine the crank/rods/pistons and so on when you can get a complete kit for around $1300 form 451 cubes to 500. Plus you can tell peopel it's just a little 383.
$1300 stroker KITS are now more like $1900 ...
[Re: RobG]
#232969
02/23/09 03:39 PM
02/23/09 03:39 PM
DaytonaTurbo
Manitoba, Canada
Power output will be fairly similar between a stock stroke 440 and a stroked 360 if you build them both for about the same cylinder head flow, then cam them similarly.
For a basic 440 build where you do the assembely and and go for like a stockish type build you could scrape by for 3500. I'd budget at least 1000 for machining, then the parts budget goes fast once you start buying intake, headers, carb, distributor, cam/lifters, pistons and related motor rebuild hardware. Then you have to decide are you going to dump money into stock heads or go aftermarket, etc. It all adds up real fast once you take a piece of paper, write everything down and add it up.
[Re: RobG]
#232970
02/23/09 04:40 PM
02/23/09 04:40 PM
Posts: 1,949 land of 10,000______'s
BDS871Cuda
A 500 HP set up, be it stroker or what not, I think would start at $5000-6000 range. For $3500 I would think you could do a stock 440 with an RV cam and stock heads. It will add up fast when you buy headers, ignition, wires, carb, and every other little thing.
As far as blocks go, 440's or 400's are all over 30 years old. So use what ever you find, if it's in good shape.
I would just do a 360 with new pistons and just toss in an Edelbrock RPM package. you will be around 425 HP with a ton of TQ. A 360 with RPM heads will be close to 250 lbs. lighter than a 440 with stock heads.
What ever you choose, I'm sure your son and you will have fun doing it. Let us know what you decide.
Snap your neck, mega G-force launch, is all I want!
[Re: RobG]
#232971
02/23/09 04:46 PM
02/23/09 04:46 PM
Posts: 5,169 CT
GTX MATT
CT
Any 440 is a good start for 500 HP if youre going to rebuild. In general iron heads, 850 CFM, a good aftermarket intake, 240-250ish duration @ .050, 1 7/8 headers, 10:1 compression and youve got a 500 hp 440.
The transmission might be one of the short tail shaft ones, I dont know which came in which motorhomes but most are the short tail shaft in which case you should buy a passenger car 727.
3500 sounds realistic but may be a little tough, if youre not going to use forged pistons it will be easier.
[Re: GTX MATT]
#232972
02/23/09 04:59 PM
02/23/09 04:59 PM
Try and get one out of a car( C-body) if you can. It saved me big $$$ when I did the conversion. The E-body and C-body mounts in '71 are the same, I used the radiator (with some minor mount trimming), the tranny, the kickdown linkage, the driveshaft and other bits and pieces. A truck to car conversion is a little more expensive because of the rear sump oil pain, different mounts etc. I did a cheapie rebuild of a good low mileage engine for around $2,600.00, did the transmission for less than $150.00 (building it myself), and a convertor for $275.00. Lots of cheap fun and 13's @ 104 mph is the result! ![](/ubbthreads/images/graemlins/drive.gif)
#232973
02/23/09 05:12 PM
02/23/09 05:12 PM
Mr.Yuck
Brookeville, Md
that is a better way to go and FWIW I had a 67 coronet w/ a 70 fury 440, stock cast pistons (maybe 9:1) 906 heads, no port work, Summit 488 cam, 1 3/4 headers, RPM intake, holley 750DP, MP ignition, 175k converter (2600) 727 and 3.91's..car ran 12.90's all day in a 3900lb car. It would take a lot of work to get the 360 to run those times in that big of a car.
[Re: Mr.Yuck]
#232974
02/23/09 06:23 PM
02/23/09 06:23 PM
RobG
Addison Twp, Mi.
You guys are great - thanks for all the advice.
What are the differences between a RV/Truck 440 and a car 440? Can someone post a pictire showing the water pump differences?
