Re: 440 Duster driveshaft length
[Re: als499]
#2329250
06/30/17 06:46 PM
06/30/17 06:46 PM
Posts: 25,902 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Shouldn't be any different than a 340 with a 727 and 8 3/4"... books says 44.99".
[Re: als499]
#2330241
07/02/17 05:03 PM
07/02/17 05:03 PM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Might as well check for tire clearance At the front of the wheel well for now and the future, should you go with a bigger tire. If the clearance is a bit tight, you can shim the front spring brackets back a little before getting a shaft made, or deciding if one is the right length.
