CHANGING OVER TO A 16 VOLT BATTERY #2328980
06/30/17 01:10 AM
06/30/17 01:10 AM
North Carolina
CALSDART Offline OP
CALSDART  Offline OP
North Carolina
I AM LOOKING TO CHANGE MY DRAG CAR OVER TO A 16 VOLT SYSTEM. THE CAR PRESENTLY HAS 2 12 VOLT BATTERIES THAT RUN THE FUEL PUMP, FAN, WATER PUMP AND MSD ELECTRONICS. WILL I NEED A STEP DOWN AND WHAT BRAND HAS EVERYONE HAS SUCCESS WITH
Calvin Thompson
Re: CHANGING OVER TO A 16 VOLT BATTERY [Re: CALSDART] #2329070
06/30/17 11:04 AM
06/30/17 11:04 AM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
Why do you need a step down? the only time I seen someone hurt their stuff was when they were on a PSC-2516A Schumacher charger.
Some discussion in this thread
https://board.moparts.org/ubbthreads/ubbt...tml#Post2185586
Joe
Without Data, you’re just another guy with an opinion.
Re: CHANGING OVER TO A 16 VOLT BATTERY [Re: sr4440] #2329095
06/30/17 11:58 AM
06/30/17 11:58 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
i used 2 16v batts on my car for years,no step down.every thing worked GREAT.i have a slightly used charger,(just sayin whistling)
Re: CHANGING OVER TO A 16 VOLT BATTERY [Re: sr4440] #2329098
06/30/17 12:04 PM
06/30/17 12:04 PM
North Carolina
CALSDART Offline OP
CALSDART  Offline OP
North Carolina
Calvin Thompson
Re: CHANGING OVER TO A 16 VOLT BATTERY [Re: CALSDART] #2329103
06/30/17 12:24 PM
06/30/17 12:24 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Just swap the batteries and go. NO reason for a step down unit...Only other concern would be if you have an alternator
Re: CHANGING OVER TO A 16 VOLT BATTERY [Re: Al_Alguire] #2329127
06/30/17 01:20 PM
06/30/17 01:20 PM
North Carolina
CALSDART Offline OP
CALSDART  Offline OP
North Carolina
Thanks for the info
Calvin Thompson
Re: CHANGING OVER TO A 16 VOLT BATTERY [Re: CALSDART] #2329451
07/01/17 02:08 AM
07/01/17 02:08 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Don't let the winging starter scare ya!
