Moser dana 60 spool issue (PICTURES)
#2327808
06/28/17 12:08 AM
06/28/17 12:08 AM
Posts: 3,097 back in Georgia
dthemi
back in Georgia
Just wanted to warn folks about a problem I've found with the moser spool for a dana. Maybe this is common knowledge, but was a surprise to me. The carrier bearing stops/flats that bearing seats against is so small in diameter that the shims between the bearing, and spool get cut in two like a cookie cutter. I have had this spool in the car for years, and at lower power, with less gear it wasn't a problem. Now that the car has power, and gear it's destroying shims because the radius under the bearing is almost as wide as the register on the spool. I looked at other spools I had around, and the moser is smaller than the others by a huge margin. The strange is twice as wide, and a mark williams is wider still. Just a warning for something to check if you're really going to put one of these spools to work. Like I said 1,000hp and a 4.56 it was fine. 1200 and a 4.88 has it cutting shims in two. I'll take a couple pics tomorrow if anyone wants to see what I'm talking about. Moser spool Mark Williams Strange spool is going in Measures 2.8 wide enough Cut shims
Re: Moser dana 60 spool issue
[Re: dthemi]
#2327988
06/28/17 11:23 AM
06/28/17 11:23 AM
Posts: 13,363 Marion, South Carolina [><]
an8sec70cuda
Thinking I may need to take closer look at mine. The Dana under my cuda was a complete Moser 60 from 2003. I've had the cover off of it once just a few years ago just to change the oil in it. From what the car has run, I'm close to 1100 hp now and it's only gonna get worse from here on out, lol. At my weight, I'm expecting some issues to pop up.
[Re: dthemi]
#2328019
06/28/17 12:19 PM
06/28/17 12:19 PM
Posts: 10,022 MN
JERICOGTX
MN
Strange spools are good to use. A friend of mine had the same issue as Darren. Caught it because the backlash was out. Went to a Strange spool now.
69 GTX
68 Road Runner
